Should I get a B16 or Type-R head ported?
Old Dec 29, 2005 | 07:59 AM
FairlightRacing's Avatar
Default Should I get a B16 or Type-R head ported?
Assuming both heads use ITR LMAs, valvetrain, etc is there any difference in flow between a B16 or Type-R head after a full port and polish? Basically, would it be worth it to send off a more expensive Type-R cylinder head to be ported versus just a standard B16 VTEC head? Or will they end up being essential the same after the headwork?
Old Dec 29, 2005 | 09:53 AM
DJsilkyjr's Avatar
pretty much the same
Old Dec 29, 2005 | 10:37 AM
Drag_Racer_DRU's Avatar
Default Re: (DJsilkyjr)
just porting the bowls pretty much turns a B16 head into a Type-R head
Old Dec 29, 2005 | 10:46 AM
theEGkid's Avatar
They use the same cast as type R. Give it a nice port job u should be nice
Old Dec 29, 2005 | 12:53 PM
wicked2night's Avatar
Default Re: Should I get a B16 or Type-R head ported? (FairlightRacing)
I'm sorry to ask this in your thread, but i must finally know. What are LMAs?
Old Dec 29, 2005 | 01:19 PM
EKhatch's Avatar
Default Re: Should I get a B16 or Type-R head ported? (wicked2night)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wicked2night &raquo;</TD></TR><TR><TD CLASS="quote">I'm sorry to ask this in your thread, but i must finally know. What are LMAs?</TD></TR></TABLE>
Lost Motion Assemblies.
Old Dec 29, 2005 | 01:25 PM
Rocket's Avatar
Default Re: Should I get a B16 or Type-R head ported? (EKhatch)
I usually tell customers to provide a good B16 head that has minimal port shift.
Old Dec 29, 2005 | 01:27 PM
EKhatch's Avatar
Default Re: Should I get a B16 or Type-R head ported? (Rocket)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rocket &raquo;</TD></TR><TR><TD CLASS="quote">I usually tell customers to provide a good B16 head that has minimal port shift.</TD></TR></TABLE>
Is that the same as core shift? I never really understood what that was anyway? Is it a shift right where the casting line is inside the port when the top and bottom may have shifted side to side?
Old Dec 29, 2005 | 01:30 PM
Rocket's Avatar
Yeah.
This is bad core shift. The port is not aligned with the valve seat. Picture is from Marcin.
Old Dec 29, 2005 | 04:02 PM
no2psi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rocket &raquo;</TD></TR><TR><TD CLASS="quote">Yeah.
What causes this shift?
Old Dec 29, 2005 | 05:43 PM
Default Re: Should I get a B16 or Type-R head ported? (no2psi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by no2psi &raquo;</TD></TR><TR><TD CLASS="quote">
What causes this shift?</TD></TR></TABLE>
I'm guessing worn valve guides which would allow the valve to be misaligned. Therefore it sits off-center and bores out a nice seat for itself.
Or I could be totally wrong.
Old Dec 29, 2005 | 08:28 PM
EKhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FairlightRacing &raquo;</TD></TR><TR><TD CLASS="quote">
Or I could be totally wrong. </TD></TR></TABLE>
I believe it has to do with when the head was originaly cast.
Old Dec 30, 2005 | 04:15 PM
Rocket's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by no2psi &raquo;</TD></TR><TR><TD CLASS="quote">What causes this shift?</TD></TR></TABLE>
Earthquakes in Japan.
Old Dec 30, 2005 | 05:03 PM
2k.civic.si's Avatar
Earthquakes in Japan. </TD></TR></TABLE>
lol
Old Dec 30, 2005 | 05:08 PM
5thgenallmotor's Avatar
Default Re: Should I get a B16 or Type-R head ported? (2k.civic.si)
Thats pretty bad for a Honda head...
That looks more like something GM would make!
Let me see if I can find some core shift pictures next week....
lilskud13
Apr 2, 2009 12:38 PM
latinf86
Aug 12, 2006 09:47 PM
larful
Oct 2, 2005 08:27 PM
B18CRMiKE
Aug 21, 2005 01:52 PM
J-Spec EG
14
Sep 15, 2004 06:48 AM
