garage sale!!! EF, EG, DA stuff ITB's as well
Here is my massive winter garage sale guys. Still have more to list, all prices negotiable and I am open to trades. What I am looking for is listed at the bottom. Finally have pics after days of going through stuff with still more to go.
Goodies
1. sold
2. sold
3. B16 MSD plug wires, hardly used at all $40
4. sold
5. sold
6. High flow 2 ¼ inch in/out brand new universal CAT converter $30
88-91 civic stuff
1. sold
2. Stock DX throttle cable $10
3. D16a6 SI intake mani with no TB or injectors $35
4. D16z6 Complete Intake mani minus FPR $60
5. HF Intake manifold without injectors $10
6. sold
7. sold
8. X2 Stock DX DPFI dizzys with no coils $15 each
9. d15b2 head and valve cover $50
10. complete set of 91 civic manual trans mounts $40
11. Idle air control valves, have a few $35
12. SI power booster $15
13.
92 95 civic coupe parts
1. D16z6 block with pistons and rods but no crank, spun bearings $make offer
2. D16z6 crank pulley with bolt $15
3. sold
4. D16z6 exhaust manifold 4-2-1 with o2 $20
5.
7. Buddy club rear bumper, never used, mounts cut out $50
9. Green front bumper in great shape, no lip $35
10. Idle air control valve $35
11. D16Z6 Throttle body with no TPS $20
12. 94-up teg shift linkage for EG b-series swap $50
13. Fog lights and fog light brackets for stock EG bumper $40
90-93 Integra Parts
1. PR4 ECU Manual Trans $50
2. Front shocks and springs together as assembly’s $25 set
3. All kinds of black and dark blue interior parts, they are all pictured below just let me know what u need and its probly here. $Take offers on whatever
4. Headlight assembly’s in ok shape, glass is good but buckets need some work mainly it’s the adjuster screw parts the buckets are not bent up, with fogs $60/set
5. Front bumper Maroon in color, good shape $50
6. Set of good corner lights one has a chip missing $10 for set
7. X2 Gauge clusters one manual and one auto $40/30
8. Power door lock assemblies, control module and switches also $50
9. X2 B18 Alternators $50 each
10. B18 manual trans starter $50
11. X3 b18 Power Steering pumps $15 each
12. Great condition black steering wheel with cruise $20
13. Energy suspension poly trailing arm bushings $15
14. Shock forks $make offer
15. Complete set of stock manual trans mounts $40
16. B18stock cam gears, 2 sets $offer
17. Misc engine brackets; alt, PS, AC have a few $offer
18. Wiper motor $15
19. Idle air control valves have several ODB0 and Odb1 $35 each
20. Map sensors have a couple $25 each
21. Stock shifter X2 $5
22. Timing belt cover plastic $offer
23. Rear sway bar with all hardware and brackets $25
24. Washer bottles with pumps $10 each
25. 40/40 prop valve for all u disc swappers $25
26. Complete AC system everything u will need $offers
27. x2 B18 ODB0 wiring harnesses with resistor boxes $25 each
28. 90-91 Half shaft (for all the swappers) $50
29. Under hood fuse boxes $offers
30. Fuel filters with brackets and lines $offers
31. Intake tube $5
32. Charcoal Canisters $offers
33. sold
34. b18 head, no cams 100,miles on it $45
Prelude parts
1. White front bumper in ok shape $40
2. White rear bumper in ok shape $20
Parts I am looking for/wtb/trade for
1. Ls/vtec oil Line kit or just sandwich adapter
2. fiberglass fenders for 91 hatchback
3. Any fiberglass front bumper for 91 hatch
4. Black carpet for 91 hatch
5. Type R intake cam or set
6. Passenger side Headlight for 91 hatch
7. Nitrous bottle, just bottle and valve needed
8. Tuner Lug nut set (blue or black)
9. Accord wagon or type R brake calipers for 11” brake upgrade
10. Wiper relay thing with the “B” on it for intermittent wipers for 90-91 hatch
Modified by D95si420 at 8:41 AM 12/31/2005
Modified by D95si420 at 10:58 AM 1/2/2006
Modified by D95si420 at 7:50 AM 1/16/2006
Goodies
1. sold
2. sold
4. sold
5. sold
88-91 civic stuff
1. sold
6. sold
7. sold
13.
3. sold
5.
90-93 Integra Parts
18. Wiper motor $15
31. Intake tube $5
33. sold
Prelude parts
i was petty sure it was off a eg 2 door, but the guy that gave them to me is not the most reliable either. I just talked to some friends that knew the guy and they said that the 2 bumpers i had were off his prelude and not the civic wich is also white
Modified by D95si420 at 9:16 PM 12/30/2005
hey dude i need an alternator to. i need to kno if its a 92 or 93 so its my obd. if it is ill send u 90 and if not 40. if all is good id like the better alt. of the 2
damn i jus saw u had a b series intake tube ill take it for 5 bux if u still have it. ill send it with the wire money if i dont get the alt.
