4th gen with moonroof?
Old Dec 29, 2005 | 04:55 AM
zenlikeme's Avatar
Default 4th gen with moonroof?
does anyone know of a moonroof that will go into a 4th gen sunroof? I'm also looking for a trunk liner for my 95 lude
thanks
kevin
Old Dec 29, 2005 | 05:21 AM
VisPreludeVtec's Avatar
Default Re: 4th gen with moonroof? (zenlikeme)
search is your friend, 5th gen glass can fit after small modifications
Old Dec 29, 2005 | 11:25 AM
StTook's Avatar
Isnt there a year for some Civic glass as well?
Old Dec 29, 2005 | 11:56 AM
Jos3ph's Avatar
i'm about to install a 2001 prelude moonroof into my 1993 prelude; just waiting for the brackets to come in. Here is a write-up for the conversion.
http://superhonda.com/forum/sh...13452
Old Dec 29, 2005 | 12:56 PM
p3t312's Avatar
Default Re: 4th gen with moonroof? (Jos3ph)
i did it in my lude pretty simple. just need the 5th gen glass and you have to drill 4 hole then the rest is just bolt on
Old Dec 29, 2005 | 02:02 PM
camil212's Avatar
Default Re: 4th gen with moonroof? (p3t312)
Just remember the moonroof is heavier than the 4th sunroof might not be many pounds heavier, but I recall it's about from 3 to 5 pounds heavier, correct me out there if I'm wrong just so you know that you will be adding more weight to your lude, if you can care less about the weight then go for it, I'm very anorexic about my prelude myself.
Old Dec 29, 2005 | 02:21 PM
StTook's Avatar
Default Re: 4th gen with moonroof? (camil212)
I would be more concerned with getting rid of potential rust
I have no need for "speed holes" hehe
Old Dec 30, 2005 | 07:34 AM
1nf3ct3d's Avatar
Default Re: 4th gen with moonroof? (StTook)
might wanna be more concerned about leaking... i know people who tried messing with their sunroofs/moonroofs and didn't fit it perfectly right, now they get wet whenever it rains. just a thought.
Old Dec 30, 2005 | 10:17 AM
p3t312's Avatar
Default Re: 4th gen with moonroof? (1nf3ct3d)
mines didnt have any leaking problems at all. just make sure everything is aligned right
Old Jan 1, 2006 | 07:10 AM
skinnyboy's Avatar
also note that the whole mechanism including the motor has to be relocated downwards about 8mm so your glass sits flush. To do this you have to remove the headliner to get to the mounting points and then shim the mechanism using washers. If you dont do this the sunroof pokes out proud of the roofline, not much but if your a picky bastard like me then you'll want to do that last adjustment!
Old Jan 1, 2006 | 12:49 PM
Dongoesby's Avatar
Default Re: 4th gen with moonroof? (skinnyboy)
The write up in superhonda.com says trim the plastic, so it sits flush, is this what you talking about?
Old Jan 2, 2006 | 01:22 AM
korney's Avatar
Default Re: 4th gen with moonroof? (Dongoesby)
how long would it take to do something like that?
96H22CD7
Feb 11, 2019 05:02 PM
TJlovesornge
Jun 3, 2008 09:00 PM
VtecPrelude95
Jul 30, 2005 06:19 PM
JDM00SI
Sep 10, 2004 12:02 PM
badtzmaru
Apr 17, 2002 01:54 PM
