will this work ???????
Old Dec 29, 2005 | 02:52 AM
ef nine's Avatar
Default will this work ???????
i just want to know that if i only got JDM sir head light+ JDM Sir hood+ sir bumper filler peice and JDM sir front bumper will the work to do that, i mean to do the conversion????? i did some serch but most of info that i got is for eg ot and ef. if it does work, what kind of modification do i need to do? thank you for all HT help.
Old Dec 29, 2005 | 05:55 AM
dr_latino999's Avatar
Default Re: will this work ??????? (ef nine)
So you are asking if you purchase the whole front end will you be able to swap it -- because you just listed everything and its cousin -- if so the answer is yes.
Old Dec 29, 2005 | 06:27 AM
staticCRX's Avatar
he didn't mention the fenders
Old Dec 29, 2005 | 06:44 AM
Default Re: (staticCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by staticCRX &raquo;</TD></TR><TR><TD CLASS="quote">he didn't mention the fenders</TD></TR></TABLE> The fenders are more of the cousin in the family that no one really likes nor mentions
Old Dec 29, 2005 | 10:44 AM
ef nine's Avatar
i mean i got almost everythings except the "radiator surrport" or " T - bar" is that the key to the convertion? i mean can i use the us radiator surrport?
Old Dec 29, 2005 | 10:45 AM
Default Re: (ef nine)
You don't need the radiator support, the stock one can be modified to work.
Old Dec 29, 2005 | 10:56 AM
ef nine's Avatar
do you had and site or a write up how to modify the radiator support?
thanks for you help dr_latino999
Old Dec 29, 2005 | 11:11 PM
SETI20's Avatar
You need a 1/2" spacer, bolts and a screwdriver to adjust your hood latch pin.
Take off the tad support/latch. Take the longer bolts and space the support out half in inch. (washers/nut will work) Carefully close the hood.
You'll see that the hood won't sit flush. Adjust the latch pin until it is.
Done. Drink a beer and **** on the JDM posers who tell you otherwise.
Old Dec 30, 2005 | 11:05 AM
ef nine's Avatar
thanks seti20for your info and to other HT members
4DRmafia
Sep 6, 2007 05:53 AM
ef9robert
31
May 17, 2007 04:56 AM
RicedREX
May 19, 2006 07:13 AM
1JDMDOMINICAN
Oct 26, 2004 04:07 PM
algunn45
Mar 8, 2002 03:20 AM
