are civic/crx radiators the same size?
Old Dec 28, 2005 | 06:47 PM
hatchinprogress's Avatar
Default are civic/crx radiators the same size?
i put a civic radiator in my crx and it looks like it sits way higher!!! (i thought they would be the same size) well it looks like the radiator sits on the front cross member fine so im stumpped
Old Dec 28, 2005 | 07:14 PM
Targa250R's Avatar
be professional
Default Re: are civic/crx radiators the same size? (hatchinprogress)
Civic 3/4/5dr MT and CRX 2dr MT rads are the same part number. The automatic rads have different part numbers but should be the same overall dimensions.
Have you measured the height of your old radiator to compare with the new one?
Old Dec 28, 2005 | 07:25 PM
gen2fanatic's Avatar
Default Re: are civic/crx radiators the same size? (Targa250R)
yes, as a matter of fact they are, i am running a crx radiator in my 90 hatch... same dimensions, hood shuts perfect...
so yes
Old Dec 28, 2005 | 09:23 PM
Eaglekper0046's Avatar
[QUOTE=Targa250R]Civic 3/4/5dr MT and CRX 2dr MT rads are the same part number. The automatic rads have different part numbers but should be the same overall dimensions.
They will all fit with no problem. The only difference is the autos have a tranny cooler at the bottom, they are also made of metal, much stronger.
Old Dec 28, 2005 | 09:34 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">Have you measured the height of your old radiator to compare with the new one?</TD></TR></TABLE> no because i bought the crx as a shell (so i didnt have a radiator)
Old Dec 28, 2005 | 10:21 PM
Try<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchinprogress &raquo;</TD></TR><TR><TD CLASS="quote"> no because i bought the crx as a shell (so i didnt have a radiator)</TD></TR></TABLE>Try and get a 88-91 auto radiator there stonger. Better yet buy a fluidyne or koyo.
Old Dec 29, 2005 | 12:36 AM
StorminMatt's Avatar
Default Re: are civic/crx radiators the same size? (Eaglekper0046)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eaglekper0046 &raquo;</TD></TR><TR><TD CLASS="quote">[QUOTE=Targa250R]The only difference is the autos have a tranny cooler at the bottom, they are also made of metal, much stronger.</TD></TR></TABLE>
Are you sure we are talking about factory radiators here? I don't think any of them are metal. However, ALL aftermarket metal radiators have transmission cooler lines since the aftermarket companies only build ONE radiator for cost saving purposes.
Old Dec 29, 2005 | 02:19 AM
crxnj's Avatar
Default Re: are civic/crx radiators the same size? (StorminMatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchinprogress &raquo;</TD></TR><TR><TD CLASS="quote">i put a civic radiator in my crx and it looks like it sits way higher!!! (i thought they would be the same size) well it looks like the radiator sits on the front cross member fine so im stumpped</TD></TR></TABLE>
Are you sure you dont have a 90-93 integra unit..??
Heres a civic/crx manual tranny raditator..
And heres a 90-93 integra unit..
Old Dec 29, 2005 | 02:40 AM
88_DX's Avatar
Default Re: are civic/crx radiators the same size? (Mr.speaker)
HF CRX's have a shorter radiator but its only like 2" shorter. the rest should just drop right in
Old Dec 29, 2005 | 03:32 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker &raquo;</TD></TR><TR><TD CLASS="quote">Are you sure you dont have a 90-93 integra unit..??</TD></TR></TABLE>
Actually, a 1990-1993 Integra radiator will often fit in a CRX. But the OEM Integra radiator is too tall for the hood to close. Not two inches too tall. Regardless, the pegs DO fit and the radiator will mount. Some aftermarket Integra radiators use the same core as the dual core Civic radiators and fit perfectly. These radiators make ideal swap radiators due to the dual core design AND the larger hose nipples, which accommodate B-series hose without problems.
Old Dec 29, 2005 | 07:37 AM
Originally Posted by StorminMatt
Actually, a 1990-1993 Integra radiator will often fit in a CRX. But the OEM Integra radiator is too tall for the hood to close. Not two inches too tall. Regardless, the pegs DO fit and the radiator will mount. Some aftermarket Integra radiators use the same core as the dual core Civic radiators and fit perfectly. These radiators make ideal swap radiators due to the dual core design AND the larger hose nipples, which accommodate B-series hose without problems.</TD></TR></TABLE>
i might have a teg radiator, because right now it's just sitting in the car (bay) with the hool down (but now latched)
SupraRXZ
Dec 18, 2006 04:30 PM
EF8 JUNKIE9
Aug 1, 2005 04:34 AM
b18-c-rx
16
Jan 17, 2005 11:40 AM
crxjake
Dec 2, 2004 10:37 AM
Hybrid Invasion
May 17, 2003 08:23 AM
