D15b7 Mini Me - Which is best? [D15 JDM Sohc Vtec Head] or [ D16z6 Sohc Vtec Head]
Old Dec 28, 2005 | 06:18 PM
JamesV's Avatar
Default D15b7 Mini Me - Which is best? [D15 JDM Sohc Vtec Head] or [ D16z6 Sohc Vtec Head]
I'm planning to do a mini me swap.. Which would be better / easier to put in?
they are both complete heads.. so yeah both are pretty much the same price..
1) Which is best?
2) Which is easier?
3) Which has the most hp stock?
Old Dec 28, 2005 | 06:23 PM
sleeper101's Avatar
Default Re: D15b7 Mini Me - Which is best? [D15 JDM Sohc Vtec Head] or [ D16z6 Sohc Vtec Head] (JamesV)
JDM D15B VTEC head = USDM D16Z6 head
exactly
Old Dec 28, 2005 | 06:39 PM
JamesV's Avatar
so its the same thing :-\
Old Dec 28, 2005 | 06:41 PM
BauleyCivic's Avatar
Risky Business
Default Re: (JamesV)
They both won't make your car fast.
Old Dec 28, 2005 | 07:05 PM
MiMiK's Avatar
hahaha!! if you got a chance to go with either one, go with the d15b head. it has a more aggresive cam.
Old Dec 28, 2005 | 07:15 PM
Br1anPham's Avatar
Default Re: (MiMiK)
Get a D16a6 cam, and adjustable cam gear, and dyno tune it.
Bauley, quit hatin punk. He bought my old head.
Old Dec 28, 2005 | 07:16 PM
adim's Avatar
The D15B does have a more aggressive camshaft, so if you have the opportunity go with it. You can also put the D15B cam into the Z6 head. Go to http://www.d-series.org for more info
Old Dec 29, 2005 | 05:13 AM
Risky Business
Default Re: (Br1anPham)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Br1anPham &raquo;</TD></TR><TR><TD CLASS="quote">
Bauley, quit hatin punk. He bought my old head. </TD></TR></TABLE>
Oh...well in that case. The D15B JDM head is awesome...if you do a 7000 RPM launch the ground will shake because of the sheer brut. On the other hand, the D16Z6 might be even sweeter. If you're in 5th and you floor it, the power delivery is so extreme that it'll pop your tires if you aren't using race compounds.
Old Dec 29, 2005 | 10:23 AM
97spooncivic's Avatar
Default Re: (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">
Oh...well in that case. The D15B JDM head is awesome...if you do a 7000 RPM launch the ground will shake because of the sheer brut. On the other hand, the D16Z6 might be even sweeter. If you're in 5th and you floor it, the power delivery is so extreme that it'll pop your tires if you aren't using race compounds.</TD></TR></TABLE>
true, you have to be careful about that when you do your mini-me. it happened to me and it sucked!
Old Dec 29, 2005 | 11:02 AM
TypeR1985's Avatar
Default Re: (97spooncivic)
I have a 92 Civic CX with a D16Z6 in it does anyone know what ECU I need 4 the V-tec to kick im I have the CX ECU in it now and it sloooooooooooooooooow!!!! &gt;
Old Dec 29, 2005 | 11:19 AM
Slimm-rw-'s Avatar
I'm a Jackass
Default Re: (TypeR1985)
Old Dec 29, 2005 | 11:57 AM
ieatrice's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeR1985 &raquo;</TD></TR><TR><TD CLASS="quote">I have a 92 Civic CX with a D16Z6 in it does anyone know what ECU I need 4 the V-tec to kick im I have the CX ECU in it now and it sloooooooooooooooooow!!!! &gt; </TD></TR></TABLE>
p28 from any 92-95 civic EX or Si
Radim
Jul 30, 2008 09:09 AM
ssbpturbohatch
May 30, 2005 09:30 AM
DOHClessEF-9
Feb 28, 2005 02:07 AM
CRXTHIS
Jan 18, 2005 06:03 AM
tSuperbike69
Feb 21, 2003 03:44 PM
