UPC/torque/advice?
Old Dec 28, 2005 | 06:14 PM
Groove_D's Avatar
Default UPC/torque/advice?
Ok, i have changed my upper control arm and followed the torque specification from the manual. The nut i'm referring to is the SELF-LOCKING NUT (10X1.25) 22 lb-ft. There is two of them in each side. They are the ones that hold the camber kit to the control arm if you got one.
Either or i left it at a spec and now when i hit a bigger bump i think that my control arm hits the upper body. It makes a nice and loud sound. Should i torque the nut to the higher spec? I had them real tight before on the aftermarket control arms but since i have put OEM control arms i wanted everything to be up to the spec.
Did anyone have similar experience and what did you do?
Old Dec 29, 2005 | 05:36 PM
Groove_D's Avatar
Default Re: UPC/torque/advice? (Groove_D)
Wow, i hear crickets.
Old Dec 29, 2005 | 07:30 PM
00IntegrAllmotoR's Avatar
HT Black OPs
i just tighten my down to spec and no prblems so far , skunk2 camber kit.
Old Dec 29, 2005 | 09:37 PM
Groove_D's Avatar
Default Re: UPC/torque/advice? (00IntegrAllmotoR)
Maybe it's my bumpstop, it's cracked in half actually, and shock is bottoming out and it seems like the UCA is hitting the body.
RSXer210
Oct 5, 2007 09:09 PM
mossimo817
Oct 18, 2004 12:24 PM
wreckedmyteg
Aug 11, 2004 06:02 PM
