Which of these part numbers (master cylinders) should I buy?
I was looking at the Majestic website and they list 3 MC for a 91 CRX. Figured I would ask here. Part numbers 86354 , 86353 , 86352 .
Here is the link, not sure if it will work.
http://www.hondaautomotivepart...INDER
And before anyone asks, I do not want to use the 15/16's from the EX as I have stock brakes and will continue to have stock brakes. Thanks in advance.
I don't know which one, but everytime I have a question...I just e-mail them and receive a reply w/ in 15-20 minutes.
i heard you can put the prelude brake master cylinder in with just bending one of the lines to fit the crx
im going to be doing that once mine gives out...just almost though
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kcjohnnyboy »</TD></TR><TR><TD CLASS="quote">i heard you can put the prelude brake master cylinder in with just bending one of the lines to fit the crx
im going to be doing that once mine gives out...just almost though</TD></TR></TABLE>
Yes you can, and in response to the author of the thread, it doesn't mean you need to upgrade the brakes. It doesn't make the car stop faster, just shortens pedal travel and improves the feel slightly. Here's my writeup: http://www.rpi.edu/~downest/Prelude_MC_upgrade.txt. There are some pics in the directory there too.
Also should mention, you can get them at any local parts store, NAPA, Advance, etc, and they are a lot cheaper. I got mine from Autozone and it's a Nissin, which I believe is OEM.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by downest »</TD></TR><TR><TD CLASS="quote">Also should mention, you can get them at any local parts store, NAPA, Advance, etc, and they are a lot cheaper. I got mine from Autozone and it's a Nissin, which I believe is OEM. </TD></TR></TABLE>
i think thats because autozone sells "rebuilt" MC. so its going to be the same as OEM. but the "rebuilt" parts are not OEM. which are just seals and such i suppose.
oh and when they list more than 1 part number, it usually means the part has been superceded and no matter which one you choose, theyll give you the newest one, or the one thats in stock. i think whenever something like the OEM manufacturer changes, its another part number. samething goes with bearings. so i dont think its an issue which one you choose.
btw, which 91 crx do you have? HF, DX or Si?
It is a 91 Si. Thanks for everyone's help, I figured that contacting Majestic would solve the problem but I like going through H-T.
I didn't want to get a reman just in case there were any problems. I plan on tracking this car pretty soon so I do not want a failure then.
zccrx
Sep 4, 2008 08:45 AM
djnikko
12
Dec 8, 2006 12:50 PM
nice writeup weird i ran into it right before im supposed to put it in
