B-SERIES Cam gears,Crower head,crank pulley,LS block,JG,Apexi,AEM good deals..
SAFC-blue face mint condition comes with instructions but no stand 150 firm...
JG Edelbrock b-series polished cam gears-175 price drop 150 mint
LS head-crower stainless steel valves,springs and retainers with mild port 300
without cam gears if you buy the head I'll throw in the JG camgears for 100 bucks still assembled ready to dropin 400..
I need aftermarket Fuel rail,TB 65MM/Bigger,LS Aftermarket IM,RIMS
ALSO HAVE A BRAND NEW MR.GASKET LS headgasket 55 shipped
I have a JDM LS Distributer with under 50k 100 shipped or picked up.. I have 1 with over 100k for 75 if you want it but personally I would get the lower mileage dizzy.
I also have extra LS Throttle bodys,Intake manifold,power steering pump,AC pump,starter,alternator and probably even more all from a OBD-1 LS motor..
I ALSO HAVE A APEXI EL boost controller mechanical with white face MAKE OFFERS....
Also got a LS block perfect for rebuild needs a fresh hone or bore was in running condtion but has been sitting atleast 1 year..175 picked up...
Also AEM b-series crank pulley polished chrome 70 bucks shipped..
I'm in fredericksburg,VA.
Modified by Samuels at 11:58 AM 1/2/2006
hey i'm interested in the head? what type of cams are in the head and also for how long was the head used, all that stuff. Also could you please post pictures thank you.
could you clarify the info on that AEM pulley? in light of the info from their website below.............
http://www.aempower.com/faq.asp?fid=28&sid=&tid=4
Question
Why doesn’t AEM make a crank pulley?
Answer
Virtually all of the cars we make Tru-Power pulleys for come equipped with a vibration dampener mounted to the crank from the factory. Aftermarket crank pulleys require the removal of these dampeners, which are required for engine life. Their removal can cause damage to your engine over time. If the manufacturers could save on vehicle costs by eliminating this device they would have done so.
Question
Answer
I don't have pics of the head. It consist of crower stainless steel valves,retainers and springs everything else is stock including cams. It comes with VC and fully assembled. It had around 10k on it.
I don't know much about the AEM undrive pulley it does say the tru power or something else like that on it has well has AEM. I will sell it for 60 bucks shipped if anybody is interested.
bump still got some good stuff left get it while you can...
I need this aftermarket LS parts.. AEM fuel rail preferably red-Throttle body can be maxbore 62mm PREFERABLY atleast 65mm-Intake manifold-Rims preferably 15's or 16's just make some offers..
I have vouches..
I have vouches..
bump to the top............................................... .................................................
