brake fluid
Old Dec 28, 2005 | 12:27 PM
RaceMyGhost's Avatar
Default brake fluid
what kind of brake fluid do you guys use?
Old Dec 28, 2005 | 01:02 PM
timmy8151's Avatar
Default Re: brake fluid (RaceMyGhost)
Valvoline Synpower Dot 3/4 fluid.
Good dry and wet boiling points at an affordable price/
Old Dec 28, 2005 | 01:34 PM
Default Re: brake fluid (timmy8151)
u like it better then hondas fluid?
Old Dec 28, 2005 | 02:13 PM
purplegsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by timmy8151 &raquo;</TD></TR><TR><TD CLASS="quote">Valvoline Synpower Dot 3/4 fluid.
Good dry and wet boiling points at an affordable price/</TD></TR></TABLE>
This is what I use too, works well. I haven't really tested the difference, but the Synpower does have better numbers in terms of wet/dry boiling point, and you can find it at any auto parts store.
Some people like ATE Super Blue because it works well and it's easy to tell when the old fluid is out of your system.
Old Dec 28, 2005 | 02:25 PM
Dogginator's Avatar
Daisy... Daisy...
Motul RBF600
Check out the brake fluids specifications here:
StopTech: Brake Fluid 1A
If you are not tracking the car, any DOT3 or DOT4 brake fluid is fine. Just change it from time to time.
Old Dec 28, 2005 | 02:35 PM
PrinceAli132's Avatar
ATE Super Blue
Ali
Old Dec 28, 2005 | 02:48 PM
toygsr's Avatar
ATE SuperBlue
Old Dec 28, 2005 | 03:44 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: brake fluid (toygsr)
Motul RBF 600. Its boiling points are much, much higher than ATE, and it's only a few bucks difference in price.
You can look up the boiling points and prices for most popular brake fluids in this topic.
Old Dec 28, 2005 | 04:15 PM
TRE_'s Avatar
Default Re: brake fluid (nsxtasy)
Honda
Old Dec 28, 2005 | 05:03 PM
Default Re: brake fluid (TRE_)
so the way to replace your brake fluid completely is to take out all the existing brake fluid in the reservior with for example a syringe, and pour in the new fluid and bleed all 4 brakes till the new fluid comes out right??
Old Dec 28, 2005 | 05:50 PM
You don't need to take out the brake fluid from the resevoir. Just start bleeding and as the level goes down, add some new fluid, and after a little while all your old fluid will have been flushed out. Just keep an eye out of whats coming out of the bleeder valve and stop when you have no bubbles and you notice your new brake fluid is coming out. The first one will take the longest, cause its the farthest side, but it gets shorter after that.
Here's a how-to, https://honda-tech.com/zerothread?id=914614
Ali
Old Dec 28, 2005 | 06:06 PM
Deluzional's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">Motul RBF 600</TD></TR></TABLE>
Old Jan 12, 2006 | 11:09 AM
OMG WTF's Avatar
Default Re: brake fluid (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">Motul RBF600</TD></TR></TABLE>
the best brake fluid ive used.
.1type.
10
Sep 6, 2006 09:26 PM
kommon_sense
Jan 4, 2005 11:46 AM
SilverDc2
Jun 6, 2004 08:54 PM
blkgsr03
Apr 16, 2004 09:21 AM
JSIR
Apr 27, 2002 10:27 PM
