B16 AXLES
Old Dec 28, 2005 | 10:55 AM
civic889802's Avatar
Default B16 AXLES
HEY I HAVE A PROBLEM IT SEEMS WIERD THAT ONE AXLE WENT IN EASY N THE OTHER WAS A BITCH #1 PASSANGER SIDE PEACE OF CAKE
#2 DRIVER SIDE WAS A BITCH BUT IT LOOKS BENDED DOES IT SUPOSED TO LOOK LIKE THAT ..
HERE IS THE PROBLEM WHEN I TRUN THE WHELLS WHEN THE CAR IS OFF ONLY 1 WILL MOVE PASSANGER SIDE THE OTHER ONE DOESNT MOVE AT ALL N SEEMS TO BE 2 HARD CANANY HELP
Old Dec 28, 2005 | 11:04 AM
RCautoworks's Avatar
Default Re: B16 AXLES (civic889802)
Do both wheel spins freely ?
People are going to tell you to take the dust rings out, if you already have done that ( like I have done in the past ) the only thing I came up with was an axle spacer I made.
Basically when you tighten the axle nut down, the axle gets pushed into the hub/knuckle causing the wheel not to spin.
Old Dec 28, 2005 | 11:31 AM
NO DRIVER SIDE DONT SPIN
Old Dec 28, 2005 | 11:39 AM
Redline130's Avatar
Default Re: (civic889802)
Did you take out the dust rings like 90blackcrx mentioned? What axles are you using?
Old Dec 28, 2005 | 11:46 AM
using 90 integra axles
what are the dust ring lol this was my first b16 project
Old Dec 28, 2005 | 11:48 AM
Search around on this site, there located inside the hub/knuckle .
Old Dec 28, 2005 | 11:51 AM
hummm. have no idea
Old Dec 28, 2005 | 12:15 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic889802 &raquo;</TD></TR><TR><TD CLASS="quote">hummm. have no idea
Took me 2 seconds to find it
https://honda-tech.com/zerothread?id=1211105
Old Dec 28, 2005 | 09:11 PM
ok this is the problem when i turn the passager side doesnt the driver side suposed to turn 2 well mines dosent n kinda looks wierd so when i put the axle straigth with no knucles it turns but when i put the nuckles it doesnt turn n sounds likes is turning from the tranny part only
Old Dec 28, 2005 | 10:14 PM
ef2_civic's Avatar
it doesn't mean it has to spin
remember unless u got a LSD transmission the other wheel doesn't move at least int he same direction
Old Dec 28, 2005 | 10:26 PM
Eaglekper0046's Avatar
Default Re: (ef2_civic)
I did a stupid thing when I did my first b16 swap by myself. I installed the passenger side on the driver, it when in like butter, but the other side was a bitch. I had to use a old wheel to get in. Like I said I had them backwards, fucked the splines. Its a long shot but it could be your problem.
Old Dec 28, 2005 | 11:13 PM
i had em like that before but nope i fix it dont both wheels have 2 turn em
CustomX113
Dec 20, 2006 10:21 AM
88crxhfb16
Aug 8, 2005 05:09 AM
G1 TEGGY
Aug 17, 2004 04:34 PM
type Gendy
Jan 19, 2003 06:18 PM
90-CRXSi
Aug 26, 2002 06:34 AM
