ls vtec and what pistons to use?
Old Dec 28, 2005 | 09:15 AM
the.hamburglar's Avatar
Default ls vtec and what pistons to use?
i searched and found that the itr pistons on the ls rods will need to be modified. so what pistons can i use so that i dont need to modify anything?
Old Dec 28, 2005 | 09:16 AM
Sack Master's Avatar
Default Re: ls vtec and what pistons to use? (the.hamburglar)
A good set of JE pistons or Wiseco
Old Dec 28, 2005 | 09:42 AM
psychotic_z's Avatar
Default Re: ls vtec and what pistons to use? (Sack Master)
I was planning on using P30 pistons off a JDM B16 for mine. ~ the same compression as ITR pistons make.
http://www.c-speedracing.com/h...c.php
ITR and CTR require modded rods (although it's not a big deal to do that).
Old Dec 28, 2005 | 10:30 AM
JDMAppeal's Avatar
Default Re: ls vtec and what pistons to use? (psychotic_z)
i know je/srp makes pistons specifically for ls/vtec
Old Dec 28, 2005 | 10:32 AM
lVlemphizStylez's Avatar
Default Re: ls vtec and what pistons to use? (JDMAppeal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMAppeal &raquo;</TD></TR><TR><TD CLASS="quote">i know je/srp makes pistons specifically for ls/vtec</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sack Master &raquo;</TD></TR><TR><TD CLASS="quote">A good set of JE pistons or Wiseco </TD></TR></TABLE>
or you could get b16 pistons for dirt cheap....which would bolt right on to your ls rods
Old Dec 28, 2005 | 03:45 PM
Default Re: ls vtec and what pistons to use? (lVlemphizStylez)
what does it ususally cost to shave the rod 1mm?
Old Dec 28, 2005 | 03:46 PM
wait what about if i go to an 81.5mm bore or even an 82mm bore. will i need to do this mod?
queda
12
Nov 1, 2007 10:05 PM
ekVtecPower
Jun 22, 2006 09:08 PM
spoonzdelsol
12
Aug 7, 2005 08:13 PM
DC-4-Drew
Jul 26, 2005 06:09 PM
DC-4-Drew
Jul 25, 2005 08:30 PM
