what booster/mc with integra brakes
Old Dec 28, 2005 | 09:01 AM
classic69's Avatar
Default what booster/mc with integra brakes
i swapped on integra front brakes, but now the pedal falls really low (the lines are bled), i guess this is because the calipers on the integra brakes are larger thus more fluid needed to press them? in either case, whats the best mc/booster to upgrade with? i searched btw. thanks
Old Dec 28, 2005 | 11:17 AM
Niftythang's Avatar
Default Re: what booster/mc with integra brakes (classic69)
I personally have done the rear disc converson to my EF DX and soon will do the front knuckle brake swap.
Since you have the larger Teg calipers; you are asking your master cylinder to pump more fluid that it dosn't have. You need to swap out your 13/16" master cylinder with a 90-93 integra 15/16" (non ABS) MC, but you NEED to use the booster as well. This isn't that bad of a swap and the booster along with the brake lines will match up perfectly.
If you have disc brakes all around, you probably should swap out your stock proportioning valve for one that says "40/40" on the side. This comes in Si and EX 88-91 civics, and DA integras.
I also recomend the braided lines all around. After I did the swap it made a huge differance in stoping force and the peddle travel is just like stock only stiffer. And that's with stock 9.5" front brakes.
Old Dec 28, 2005 | 11:18 AM
Niftythang's Avatar
Default Re: what booster/mc with integra brakes (Niftythang)
This is a good resource for you to look at,
http://www.ef-honda.com/ben/EFhybridsus.php
Old Dec 28, 2005 | 11:27 AM
CRX Toad's Avatar
He is correct grab an Integra Booster that says 260V (non abs) on the plaque and the MC and they will bolt in. It can be a pain but it isn't bad. I love my Integra Booster/MC. I also have 260V booster/MC for sale.
Old Dec 28, 2005 | 11:35 AM
classic69's Avatar
awesome link
so the 88-91 prelude MC will bolt right in my stock booster then? or should i put in the DA MC/BOOSTER instead?? will either give me good results?
Old Dec 28, 2005 | 11:38 AM
CRX Toad's Avatar
DA booster/MC > Prelude
Old Dec 28, 2005 | 04:58 PM
classic69's Avatar
Default Re: what booster/mc with integra brakes (CRX Toad)
got an MC out of a 89 Accord LXi today so putting it in tomorrow see how it works out
Old Mar 9, 2006 | 05:54 PM
ONEFASTJDM's Avatar
any updates?
Old Dec 18, 2006 | 06:38 PM
KansasKev's Avatar
I plan on doing this upgrade to my 91 crx si.
So I need:
90-93 Integra(non-abs) brake booster and master cylinder?
I wonder if the auto parts store will have these?
Old Dec 18, 2006 | 06:43 PM
EL Vap133's Avatar
Default Re: what booster/mc with integra brakes (KansasKev)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KansasKev &raquo;</TD></TR><TR><TD CLASS="quote">I plan on doing this upgrade to my 91 crx si.
So I need:
I wonder if the auto parts store will have these? </TD></TR></TABLE>
Correct, and yes they should have those parts.
Old Dec 18, 2006 | 06:54 PM
KansasKev's Avatar
Default Re: what booster/mc with integra brakes (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">
Correct, and yes they should have those parts. </TD></TR></TABLE>
Thanks.
I will call and get a price tomarrow and post it.
Old Aug 5, 2007 | 11:30 PM
Civic89stdB16's Avatar
will the 90-91 ex civic mc work on a 89 std civic hatch. Please let me know. I have the integra knukles and the pedle is a little low. Thanks
Old Aug 6, 2007 | 12:07 AM
xanonymousx's Avatar
Default Re: what booster/mc with integra brakes (Civic89stdB16)
Go to the autoparts store and buy a 1990 integra non-abs master cylinder/brake booster. You are probably looking at around ~300 dollars without the cores returned.
Old Aug 6, 2007 | 12:12 AM
Default Re: what booster/mc with integra brakes (xanonymousx)
will the brake lines line up on my 89 std
Old Aug 6, 2007 | 07:51 AM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic89stdB16 &raquo;</TD></TR><TR><TD CLASS="quote">will the 90-91 ex civic mc work on a 89 std civic hatch. Please let me know. I have the integra knukles and the pedle is a little low. Thanks</TD></TR></TABLE>
Yes, the 90-91 EX MC is a perfect fit!
Old Aug 6, 2007 | 07:52 AM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic89stdB16 &raquo;</TD></TR><TR><TD CLASS="quote">will the brake lines line up on my 89 std</TD></TR></TABLE>
The EX and Integra non-ABS MC will fit, brake lines will line up.
Old Aug 6, 2007 | 01:54 PM
thanks
Old Dec 14, 2007 | 09:59 AM
gunnerman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xanonymousx &raquo;</TD></TR><TR><TD CLASS="quote">Go to the autoparts store and buy a 1990 integra non-abs master cylinder/brake booster. You are probably looking at around ~300 dollars without the cores returned.</TD></TR></TABLE>
Just buy the 90-91 EX MC and you wont have to change your brake booster. When I checked prices a few months ago they were around $70-90 before core charge
Old Apr 4, 2010 | 08:24 PM
Mr. smith's Avatar
can you used a abs brake booster?
Old Apr 5, 2010 | 05:54 AM
dr_latino999's Avatar
Bad Canadian, bumping such an old thread; think because you had the Winter Olympics you can do anything you want
I don't believe you can use the ABS booster, but I can't tell you the exact reason. Now of course this is a twenty year old Honda and not a B-2 stealth bomber so with some finaggling you can make it work, but the question is if it is worth it to you.
Old Apr 5, 2010 | 07:19 AM
DukeVonDANK's Avatar
Check out the 4-door hatch Master Cyl. It'll match up to your EF lines, and it's cheap as heck! I paid $48 bucks for mine, and it's a 15/16. The integra ones are more expensive, and the lines from the car needs bent like 15 degrees.
Old Apr 5, 2010 | 07:34 AM
Let me clean that up for you.
Originally Posted by Me
Check out the 1990-91 sedan EX Master Cyl. It'll match up to your EF lines, and it's cheap as heck! I paid $48 bucks for mine, and it's a 15/16. The integra ones are more expensive, and the lines from the car needs bent like 15 degrees.
Old Apr 5, 2010 | 04:39 PM
Mr. smith's Avatar
i got the non abs mc 15/16 . but can you used the abs booster or dos that have to be non abs ?
Old Mar 8, 2013 | 01:37 AM
myefhasaname's Avatar
Bumping for at home use
Old Jul 8, 2015 | 08:29 AM
Nuckz23's Avatar
Hate to bring this back from the dead but I'm looking for assistance. I recently bought an 89 civic si hatch that had the rear disk swap from a 90 crx si. So now I have disk brakes all around. I am noticing that the peddle is soft and sometimes I lose braking. I'm pretty sure my MC is going out. So, I'm looking at swapping in a 90 integra booster and MC. Is this an adequate swap or should I be looking for something else? FYI the link above :#GRIDLIFE is not the correct one anymore
