Help needed on painting JDM ITR wheels
Old Dec 28, 2005 | 07:48 AM
NeriVTEC's Avatar
Default Help needed on painting JDM ITR wheels
I have the JDM ITR wheels (96-97) and I need some help on restoring them because the shop took off a lot of the color when fixing the bent rim. I want to repaint them white like they come but don't know which paint to use and if it would be wise to use the Aircraft Remover method only without sanding anything and if it will remove all of the old panit and leave it bare so that I can repaint them. Any help will be appreciated. Thanks.
Old Dec 28, 2005 | 09:02 AM
Padawan's Avatar
Darth ModerVader
Default Re: Help needed on painting JDM ITR wheels (NeriVTEC)
Aircraft stripper should get them down to bare alloy. As for the paint, the original color is Championship White (NH-0).
Old Dec 28, 2005 | 06:14 PM
uNF$@#!'s Avatar
Default Re: Help needed on painting JDM ITR wheels (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">Aircraft stripper should get them down to bare alloy. As for the paint, the original color is Championship White (NH-0). </TD></TR></TABLE>
unless you are willing to powdercoat them you are probably better off sanding down the paint a little with a medium grade paper then painting over them with aerosol...
allmotorkid
Dec 28, 2010 04:34 PM
WyldRice
Paint and Body
Apr 21, 2008 09:46 AM
NeriVTEC
Jan 8, 2006 08:19 PM
Supraznki
Apr 20, 2005 07:29 PM
AllMotorDC5erBooyah!
Jan 29, 2004 04:45 PM
