energy suspension bushings
Old Dec 28, 2005 | 01:51 AM
dsmarefaster's Avatar
Default energy suspension bushings
whats the best way to take the olds out can i burn them out if i cant get them out?
Old Dec 28, 2005 | 02:00 AM
TurBoTeG's Avatar
i used grilling bricketts ...got them nice and hot...put the piece on and burned the rubber out...then took a hack saw to the outer metal sheeth jus enough to cut through and poped it out with a screw driver.....i had a vice to help me install the new bushings
Old Dec 28, 2005 | 06:59 AM
danthemang3's Avatar
Default Re: (TurBoTeG)
drilling the rubber out is def. the easiest. trust me i did rear trailing arm bushings, an air powered hack saw couldn't even do it. i drilled the bushing out then the left over rubber i took the dremel to. you can burn them out but i would only do it if the entire part is off of the car. the rubber won't just melt it will catch on fire.
Maxman
Suspension & Brakes
May 6, 2014 05:21 AM
erebunicrx
10
Mar 12, 2005 06:45 PM
95hbMatt
Dec 27, 2003 05:15 PM
thrill91si
May 16, 2003 09:34 AM
wuhungsixxx
Oct 5, 2001 11:03 AM
