Is there a way to put down my windows?
This is for the rear passanger window on a 4dr Integra
Okay well my car got into a wrecked some time back, and I started stripping down the whole car, and me beeing smart forgot to put the window down. So now I need to take out the window, but the window is rolled up, and all the wiring hardnest is taken off... So what should I do now? I need to put the window down to unbolt it. Any info would help!
Thank YOU!
Thank YOU!
hmm...you can try this but I really dont know if it'll work.
Reconnect the power window switch. Find the power wires coming from the power window switch, cut/extend them and connect it to a car battery, see if you can operate the window.
If that doesnt work, see if you can remove the window from the frame by removing the two 10mm bolts that hold it to the actuator rail. Since your window is rolled up, it'll be damn hard to get in there with tools and remove the bolts. However, once you do, the window will be loose enough to pull out of the door.
Yes I know, but the thing is the window is all the way up, and the track is right behind the door, and can't see or can't get a hand up there... if there no other way I will just cut the door apart...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DirtyBirdJR »</TD></TR><TR><TD CLASS="quote">is the motor still intalled. try hooking up a 12v to the motor. if it goes up reverse the polrity GL</TD></TR></TABLE>
Yup motor is still there, I was thinking of just hooking up the to the battery but was affraid that I might burn the motor...
It shouldnt screw up the motor, the car battery powers everything in the car anyways right? Anyways, you're just gonna power it up for a few seconds, just to get the window down.
92-CivicLX
Sep 23, 2013 07:46 AM
