del sol seats help
what size are the hardware holding the Sol seats to the seat pans, i know theres four of them, i was wondering if i can use the sol hardware on my ek
Modified by JDMedEK at 10:48 PM 12/27/2005
Modified by JDMedEK at 10:49 PM 12/27/2005
I just installed del sol seats into my 00 ex. The sol seats are not a direct fit so you have to swap the ek rails to the sol seats. Not hard but it takes some time.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by artificeexks »</TD></TR><TR><TD CLASS="quote">The last time I check, only three of the bolts were the same and the ones closest to the center console (the rear) were different!</TD></TR></TABLE>
I think its the front center console on thats bigger
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00ekcoupe »</TD></TR><TR><TD CLASS="quote">I just installed del sol seats into my 00 ex. The sol seats are not a direct fit so you have to swap the ek rails to the sol seats. Not hard but it takes some time.</TD></TR></TABLE>
Are the seats really low? I traded for a EK hatch with del sol seats and they are on the original rails (drilled holes to fit). They sit really really low though.. I'm 6'3 and i can't quite see the hood even..
I actually had both these seats in my del sol... Find ek rails because the del sol seats are not a direct bolt on. You’ll figure it out when you try to install them. And as for the bolts, mine were (3) 10mm with a 12 head and (1) was a 14 head with a 12mm thread.
Go to autozone and pick some up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by urname7698 »</TD></TR><TR><TD CLASS="quote">
Are the seats really low? I traded for a EK hatch with del sol seats and they are on the original rails (drilled holes to fit). They sit really really low though.. I'm 6'3 and i can't quite see the hood even.. </TD></TR></TABLE>
Sol seats always ride low in civics, that's one reason people don't put civic seats in del sols.
99civic_coupe
Feb 3, 2013 10:11 AM
