Looking for custom radiator...
I am looking to get a custom radiator made for a little project I have going on.
I currently have this radiator:
I want to be able to lay it on its side, and have the openings relocated like so:
Now, I know its not likely possible to do with the radiator I have but I was wondering if anyone out there could be able to do something like this.
Thanks in advance for any help,
Julian
Julian
it would be just as big, because the way the rows flow. you cant add a neck on the edge of one row. you would have to have new end tanks fabbed to flow around to the side to where you want the filler necks. you need to get a custom one made from scratch.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dfoxengr »</TD></TR><TR><TD CLASS="quote">for probably cheaper you could get a thinner one</TD></TR></TABLE>
its not the thickness thats the problem, its the height.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90DALS »</TD></TR><TR><TD CLASS="quote">you need to get a custom one made from scratch.</TD></TR></TABLE>
any sources?
any sources?
The closest I can think of would be a scirocco radiator like this, it's 22"x13"
Or just call C&R and they can make you pretty much what ever you need.
If thats an aluminum core new endtanks can be welded on. The filler cap would have to be on the top of an endtank though...not mid-core. Its not terribly hard.
Contact Ken@Phoenixturbo.
http://www.phoenixturbo.com
For the evo8 kit a evo6 style radiator is needed. They take the customers stock evo8 rad and modify them with new tanks to be evo6 style.
AF-Performance
http://www.af-performance.com
AF-Performance
i meant thinner as in wideness, not thickness. height you can find what you need too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fred n J’s_1.8’s »</TD></TR><TR><TD CLASS="quote">its not the thickness thats the problem, its the height.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dfoxengr »</TD></TR><TR><TD CLASS="quote">i meant thinner as in wideness, not thickness. height you can find what you need too.</TD></TR></TABLE>
oh, i see. i really dont want to go out and experiment if i could get something made.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by af-performance »</TD></TR><TR><TD CLASS="quote">Contact Ken@Phoenixturbo.</TD></TR></TABLE>
thank you sir, will do.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k20 jon »</TD></TR><TR><TD CLASS="quote">If thats an aluminum core new endtanks can be welded on. The filler cap would have to be on the top of an endtank though...not mid-core. Its not terribly hard. </TD></TR></TABLE>
yeah, i believe it is an aluminum core but with plastic endtanks. i dont mind the endtanks ending up in different spots, all i really care about are the dimensions and hose openings being in that spot or close to it.
-julian
thank you sir, will do.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k20 jon »</TD></TR><TR><TD CLASS="quote">If thats an aluminum core new endtanks can be welded on. The filler cap would have to be on the top of an endtank though...not mid-core. Its not terribly hard. </TD></TR></TABLE>
-julian
Check out http://www.summitracing.com for their universal radiators. I found it easier looking through their catalog rather than their website since all the radiators and sizes were in front of me.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Want2race »</TD></TR><TR><TD CLASS="quote">Griffin just made me a custom radiator.
Look on their site under custom and print the PDF, fill it out and fax it back.. They will discuss all the details with you!</TD></TR></TABLE>
how much did that cost???
hotimportcrx
10
Mar 27, 2005 06:54 PM
