D16a1 Swap, The motor is in!! Mod List.
Just droped it in today and its sitting pretty! Here are a few pics.
Mods:
ENGINE
-MSD 6A IGN
-MSD Blaster 3 COIL
-MSD Dist Cap.
-NGK V Power Plugs
-Complete Rebuild
-ZC Cams
-B16 Injectors
-Ported Intake
SUSPENSION
-Weapon R Coilovers 500LB Springs
-Upgrade Motoring 27.5mm T bars
-ES Hyperflex Kit
-Custom Teg Rear Sway Bar
-Custom Traction Bar
-RPR Panhard Bar (Thanks Tom it works great)
-SSR Mesh Wheels (14x8) not the ones pictured
-Nitto Drag Radials
INTERIOR
-Tenzo R Seats (RED)
(Soon to have a full roll cage)
COOLING
-EG Dual Core Radiator.
FUEL
-8 Gallon Fuel Cell
-MSD Fuel Pump
Mods:
ENGINE
-MSD 6A IGN
-MSD Blaster 3 COIL
-MSD Dist Cap.
-NGK V Power Plugs
-Complete Rebuild
-ZC Cams
-B16 Injectors
-Ported Intake
SUSPENSION
-ES Hyperflex Kit
-Nitto Drag Radials
INTERIOR
COOLING
FUEL
-8 Gallon Fuel Cell
-MSD Fuel Pump
That half core is also a dual core so it'll cool just as good if not better than the full size. Plus it's tight in that engine bay anyhow so if I can free up some extra room I will. Plus there might be a little forced induction in the future
The only differences between d-series trannies is the gearing and spline counts (I'm counting flywheel/clutch as seperate entity). I would guess the teg trans would have better gearing. Regardless, its a fun engine. I had a teg with one in it, and it was only the [auto] trans that left a bad taste in my mouth.
Those rims are actually what I noticed 1st.
Pimp that early-90's style with pride!
actually the stock tranny would not work with the d16.
looks good. is it a blacktop or did you paint the valve cover black? we are about to do a browntop swap on my friends 87 si
Yep, it's a stock 89 teggy motor that was rebuilt fresh. I did a complete change over from the 89 integra that I had.
2KTEG I got all of my tranny bolts to go in fine.
brixity
Dec 5, 2005 06:15 AM
