question about making my own spark plug cover
what tools would i need to make my own spark plug cover? i have a b18c1 and i can get the dimensions. also what type metal would be the best to use? preferrably something that doesn't look plain-jane or cheap. i'm pretty handy with tools and things of that nature, so i'm thinking about giving this project a go. for the smart asses...go easy on me. i'm new on the honda scene and just looking for info to get my **** looking better. thanks for any info.
if you take a look at how a stock one sits, from where it bolts down, to the top of it, where it sits flush with the top of the valve cover, it is raised a bit.. so depending on how you want it to look will be how difficult it will be to make..
if you just want to make a plate, flat with where it bolts down, it will sit a little bit lower then the valve cover, and not looking as clean..
to make it fit nicer, you would have to bend the edges so it in a way, makes it as a step-up..
