is my 95 ls wired for vtec
Old Dec 27, 2005 | 04:56 PM
downeyballz's Avatar
Default is my 95 ls wired for vtec
is my 95 ls wired for vtec from the factory? not the motor, but the car?
Old Dec 27, 2005 | 04:59 PM
nickG's Avatar
Default Re: is my 95 ls wired for vtec (downeyballz)
you need 4 more wires for vtec AFAIK
i know some of the canadian hatches are.
Old Dec 27, 2005 | 06:58 PM
StolenTeg's Avatar
what do you mean wired for vtec? your is ls meaning it is non-vtec
Old Dec 27, 2005 | 08:23 PM
Sack Master's Avatar
Default Re: is my 95 ls wired for vtec (StolenTeg)
He wants to know if the factory chassis harness on a 95 ls is the same as the factory chassis harness on a 95 gs-r. I'm 95% sure the answer is no. I think the newer ones are though but I may be wrong.
Old Dec 28, 2005 | 06:12 AM
Default Re: is my 95 ls wired for vtec (Sack Master)
so the factory chassis doesnt have the wires? that is my question, does anyone have a definate answer?
Old Dec 28, 2005 | 07:27 AM
Novtecdohc's Avatar
no, your 95 LS is NOT wired for vtec... Just get a Vtec ecu and run your 3 wires your self and call it a day.
Old Dec 28, 2005 | 01:03 PM
Default Re: is my 95 ls wired for vtec (Novtecdohc)
yeah i already have everything i need, i had to do it in my old del sol. i was just courious
Old Dec 28, 2005 | 07:37 PM
steveshow's Avatar
Not to be an A hole or anything, but did you ever consider OPENING THE HOOD AND LOOKING AROUND??? I would think if you swapped the motor yourself, you would have noticed any extra plugs/wires, especially if you have doen a swap before...
Old Dec 28, 2005 | 07:43 PM
Default Re: is my 95 ls wired for vtec (steveshow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by steveshow &raquo;</TD></TR><TR><TD CLASS="quote">Not to be an A hole or anything, but did you ever consider OPENING THE HOOD AND LOOKING AROUND??? I would think if you swapped the motor yourself, you would have noticed any extra plugs/wires, especially if you have doen a swap before...</TD></TR></TABLE>Popping the hood isn't really going to tell you what wires are under the dash homie.
Old Dec 28, 2005 | 09:44 PM
DC2TEGGA-GSR's Avatar
i doubt thats its wired for it...there would be no point for honda to waist time and money on the wires for vtec, hoping that someone would take each LS and put a vtec head on it. But then again, i might be wrong.
marcelo17
Apr 21, 2005 06:24 AM
FreeMyndz v.FP
Nov 27, 2001 07:58 PM
