cracked ring, wat to do now?
Have a shop perform a leak down test to find out where the leak is coming from. Replacing a valve is a bit easier than replacing rings (and cheaper).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silverboost »</TD></TR><TR><TD CLASS="quote">one of my cylinders has 65 pssi compression, wat do i do now? Swap the motor? buy an oem piston, rod, and rings? wat would some of u guys do?</TD></TR></TABLE>
I would call 1-800-ABC-DEFG to learn how to spell "what". Hooked on phonics works for me!!
jk. Seriously though get a leakdown test like that last guy said. It'll help let you know what specifically is causing the problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-97CX »</TD></TR><TR><TD CLASS="quote">Are you sure it's a ring? It could be a burned/bent valve as well.</TD></TR></TABLE>
Very likely it could be a valve problem. If it is a bent valve, the piston could be damaged too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">I would call 1-800-ABC-DEFG to learn how to spell "what". </TD></TR></TABLE>
lol
lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silverboost »</TD></TR><TR><TD CLASS="quote">wat if i only replace one piston w/o re honig????</TD></TR></TABLE>
you should do all four pistons.. besides, i don't think you can buy rings for just one piston.. better buy after market forge pistons and rings!!
although, it ain't cheap..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by transpar_nt »</TD></TR><TR><TD CLASS="quote">
I would call 1-800-ABC-DEFG to learn how to spell "what". Hooked on phonics works for me!!</TD></TR></TABLE>
he still spells it the same way, haha. i dont think you should buy a new block, isnt that more expensive than rehoneing or replacing a valve. if you fix it right, it will be just as good as before
jadugartir
Aug 1, 2004 07:05 AM
