how do i properly replace my slave clutch master cylinder?
Old Dec 27, 2005 | 02:53 PM
candy eg's Avatar
From: The Real O.C. Oakland Chinatown, California, USA
Default how do i properly replace my slave clutch master cylinder?
yea, i know this is simple to many of you guys and it would be easier to make remarks like "OMG newb" blah blah blah, but i am just a dumb kid trynna fix his car, so please help. step by step and please be very specific as for i dont know **** about fixing cars.
Old Dec 27, 2005 | 03:42 PM
candy eg's Avatar
Default Re: how do i properly replace my slave clutch master cylinder? (candy eg)
help, im bored at home and its winter break!!!!!
Old Dec 27, 2005 | 03:47 PM
highroller54's Avatar
are you changing the slave or master or both?
Old Dec 27, 2005 | 04:02 PM
candy eg's Avatar
Default Re: how do i properly replace my slave clutch master cylinder? (highroller54)
just the slave, i already did the master cylinder that was leaking but that was with help.
Old Dec 27, 2005 | 04:29 PM
its 2 bolts and a line, then bleed
Old Dec 27, 2005 | 05:29 PM
candy eg's Avatar
i know im a newb, but how do i bleed it?
Old Dec 27, 2005 | 05:32 PM
Brian Hinson's Avatar
Basically the same way you bleed your brakes. Have some one pump the pedal while you let the air out of the lines.
Old Dec 27, 2005 | 05:57 PM
Heinz57's Avatar
Default Re: how do i properly replace my slave clutch master cylinder? (Brian Hinson)
its mos def. like bleeding brakes.
it has the little bleeder screw right infront of it, so same process of bleeding brakes. pump brakes, hold pushed down; untighten bleed screw - let air/fluid out; tighten bleed screw, and do steps over until fluid comes out with no air bubbles.
Old Dec 27, 2005 | 07:06 PM
candy eg's Avatar
Default Re: how do i properly replace my slave clutch master cylinder? (Heinz57)
thx, ill give it a try tmw.
Old Dec 27, 2005 | 07:32 PM
Hybrid96EK's Avatar
1). Loosen line to cylinder. I think its a 10mm. Make sure you use a tubing wrench unless you want to hose it up. Don't remove it all the way yet
2). Remove two 12mm bolts
3). Put pan under area of slave
4). Remove line
5). Remove slave
6). Position new slave cylinder, make SURE the rod is seated correctly into the release fork. Lube end of rod with grease if needed
7). Tighten two 12mm bolts to hold cylinder to tranny
8). Install and tighten line to back of cylinder. Again, use the right wrench
9). Bleed system just like you would brakes
Johnmadsen
Apr 15, 2018 03:16 PM
h22lude317
Mar 2, 2009 09:06 PM
asianalbutt
Jan 12, 2006 12:51 PM
92integraVTECgsr
Nov 4, 2005 05:39 PM
yOnKiNaToR
Oct 23, 2005 05:44 PM
