Door locking mechanism - bars and things (not locking)
Old Dec 27, 2005 | 01:57 PM
Takumi Fujiwara's Avatar
Default Door locking mechanism - bars and things (not locking)
when I hit the lock button on my car (doors closed), the driver's side door does not lock. It manual lever thing (red rectangle) only pulls like 1/2 way and does not lock the door.
I took the door panel off to try and get a better idea of what was going on. There seems to be no damage to the rod itself. If it makes any sense, it feels like the plastic manual lever does not have enough torque. If I pull on the rod it locks pretty easy. Does this sound like an easy, oil it to fix it issue? If so, where do I oil it? The other end of the rod goes to the door jam edge of the door.
Old Dec 27, 2005 | 06:24 PM
Default Re: Door locking mechanism - bars and things (Takumi Fujiwara)
back to page 1 please...
Old Jan 2, 2006 | 01:15 PM
Old Jan 2, 2006 | 01:18 PM
Dogginator's Avatar
Daisy... Daisy...
Do the driver and passenger mechanisms require the same effort to manually lock? If so, your actuator may be failing.
Old Jan 2, 2006 | 01:46 PM
Default Re: Door locking mechanism - bars and things (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">Do the driver and passenger mechanisms require the same effort to manually lock? If so, your actuator may be failing.</TD></TR></TABLE>
It is just the driver's side door.
Old Jan 2, 2006 | 04:03 PM
xintegragsrvtecx's Avatar
I'm guessing your drivers side door is open when you do this? If so it's a acura safety thing I think. When the door is open pull the handle from the inside and lock it.
Old Jan 2, 2006 | 04:52 PM
Soulchaz's Avatar
My 96 does the same thing, I have to pull the handle on the inside, then lock it...and my passenger side lock sometimes makes a machine gun like noise, like its not catching, and I have to manually lock it....Let me know if you find anything out Takumi ok? Thanks.
-Kyle
Old Jan 2, 2006 | 05:11 PM
Default Re: Door locking mechanism - bars and things (xintegragsrvtecx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xintegragsrvtecx &raquo;</TD></TR><TR><TD CLASS="quote">I'm guessing your drivers side door is open when you do this? If so it's a acura safety thing I think. When the door is open pull the handle from the inside and lock it.</TD></TR></TABLE>
It doesn't matter if the door is closed, or if I pull the handle and to lock it. It's the same result... difficult to lock. i.e. most of the time when I arm my alarm, the driver's side door does not lock any more.
If the door panel off & the handle pulled, I have to pull on the upper rod a couple times, and relatively hard to get it to lock.
Old Jan 2, 2006 | 05:21 PM
Dogginator's Avatar
Daisy... Daisy...
Is the driver door lock more difficult to manually lock than the passenger door lock?
Old Jan 2, 2006 | 05:23 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">Is the driver door lock more difficult to manually lock than the passenger door lock?</TD></TR></TABLE>
correct.
Old Jan 2, 2006 | 05:48 PM
Dogginator's Avatar
Daisy... Daisy...
Are you getting the machine gun sound? If not, you probably have a problem with the "safety" catch in part #25. Especially since you cannot manually or automatically lock the door regarless of whether it is open or closed.
This may be beyond a simple oiling fix.
Old Jan 2, 2006 | 05:55 PM
ninhers's Avatar
I had the same problem happen to my car. There is a rod that is attached to the inside of the door latch. This rod may be off alignment. This is the safety feature so that you don't lock the door before it is closed. Remove the door handle and the three screws holding the latch on to access this part. Good luck
Old Jan 2, 2006 | 05:57 PM
eag36's Avatar
Default Re: (ninhers)
had the same thing on my car... had a write up on it a while ago... i'm gonna search, be back soon.
Old Jan 2, 2006 | 06:07 PM
eag36's Avatar
Default Re: (eag36)
can't find it.... is there a way you can search for replies by user name or only threads started?
Anyway, long story short I disconnected the door lock linkage going from the interior manual door lock to the locking mechanism. I don't remember if i removed it or if i cut it... but i can no longer lock my door manually. that solved my problem. I never use that manual switch anyways.
Old Jan 2, 2006 | 06:08 PM
Default Re: (eag36)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eag36 &raquo;</TD></TR><TR><TD CLASS="quote">had the same thing on my car... had a write up on it a while ago... i'm gonna search, be back soon.</TD></TR></TABLE>
I'll look for this write up too...
My friend has a spare one, I think I might grab his and atleast have a spare.
Old Jan 2, 2006 | 06:18 PM
reno96teg's Avatar
have you tried lubing up the linkage? may not be it, but my locks were getting pretty tough to move, and all it needed was lubricating.
Old Jan 2, 2006 | 07:43 PM
Default Re: (reno96teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by reno96teg &raquo;</TD></TR><TR><TD CLASS="quote">have you tried lubing up the linkage? may not be it, but my locks were getting pretty tough to move, and all it needed was lubricating.</TD></TR></TABLE>
Where exactly would you oil it?
Old Jan 2, 2006 | 07:54 PM
brandons 95ls's Avatar
Default Re: (Takumi Fujiwara)
i had the same problem with my 95ls take door panel off and oil (wd-40) the end were the linkage conects to the latch and soak the hell out of it and it should work
Old Jan 2, 2006 | 09:14 PM
Default Re: (brandons 95ls)
I think I'll remove that thing at the latch and oil it with the "special" lube..uh uh FOR REAL THOUGH.
Old Jan 3, 2006 | 05:24 AM
reno96teg's Avatar
i actually used white lithium grease instead. lube anywhere the linkage is connected, and anywhere it may rub against anything.
Old Jan 5, 2006 | 05:58 PM
J.nguyen's Avatar
i have the same modafuckin problem.. just got car back from impound and it dsnt lock https://honda-tech.com/zerothread?id=1483785
imma try that wd-40 method and hope it works..
Old Jan 5, 2006 | 06:09 PM
J.nguyen's Avatar
WOW WD-40 WORKS MIRACLES OMFG WOW, i just did it and it work with no problem.
Old Jan 5, 2006 | 08:15 PM
OneTyteEK9's Avatar
B A N N E D
you need a new acculater because that same thing happen to my integra
Frost7177
Oct 27, 2008 01:31 PM
raphael
Paint and Body
11
Nov 8, 2007 05:36 AM
zoolander
Mar 5, 2006 08:22 PM
97itr86
Dec 31, 2004 02:06 PM
FR-MOB: ThE bEe GuY
Jul 14, 2003 09:11 AM
