Changed headgasket and now car wont start!!! FRUSTRATION!!!!!!!!!!!!!!!
Old Dec 27, 2005 | 01:49 PM
98B18C1's Avatar
Default Changed headgasket and now car wont start!!! FRUSTRATION!!!!!!!!!!!!!!!
i took off my head to change the headgasket and got my head resurfaced and cleaned...i put everything back on and it started so i took it home...the next day i tried starting it and it doesnt turn over. battery was kinda low so i jumped it and still doesnt start. there is spark and fuel but i dunno if the injectors are clogged (shouldnt be cause it drove the day b4 and there is fuel pressure) now im clueless...can it be that i didnt do a valve adjustment? maybe dizzy? dizzy cap? rotor? any help would be appreciated guys. Thanks...btw my car is turboed also
Old Dec 27, 2005 | 02:02 PM
vanos_pusha's Avatar
Default Re: Changed headgasket and now car wont start!!! FRUSTRATION!!!!!!!!!!!!!!! (98B18C1)
did you check the timing?
Old Dec 27, 2005 | 02:35 PM
Lauj87's Avatar
You sure it's just not your starter going bad?
Old Dec 27, 2005 | 02:52 PM
sykotic's Avatar
Default Re: (Lauj87)
Make sure you plugged everything back in correctly, make sure your injectors are plugged in right, check everything connection on the intake manifold and distributor. Make sure every cylinder is getting spark/fuel, don't just check it at the distributor or at the fuel rail.
Old Dec 27, 2005 | 07:00 PM
98B18C1's Avatar
timing i do not know because i dont have the gun but the timing belt was put on correctly with everything at TDC. I tried adjusting the distributor back and forth but that didnt help either. Everything was plugged in correctly and it ran fine wen i was driving home but was kind of running lean and was choking at low rpms...i will try to plug in my msd and see if that helps...how can i check if my injectors are clogged? and if they are is there any place in norcal that cleans injectors? can this have anything to do with bottom end components like if a ring is blown or not?
Old Dec 28, 2005 | 03:29 PM
98B18C1's Avatar
aight this morning i took off my stock coil and put on my msd setup and now the car turns on and runs but at partial throttle it pops and chokes like crazy!!! (wont go anywhere) no i have a feeling that my turbo might be blown??? cause i hear weird sounds from it...can this be it?
Old Dec 30, 2005 | 12:37 AM
98B18C1's Avatar
put everything back to stock and it still does it...running lean and backfiring like crazy so i dunno now...any help guys?
Old Jan 2, 2006 | 09:07 AM
Naya the Dingo's Avatar
Did you just fill up with gas? Could it be a batch of bad gas? What do the plugs look like? Do you have another distributor you could swap out and test?
Old Jan 2, 2006 | 09:34 AM
illmaticimports's Avatar
do a compression check than return us with more info
Old Jan 2, 2006 | 11:12 AM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98B18C1 &raquo;</TD></TR><TR><TD CLASS="quote">can it be that i didnt do a valve adjustment?</TD></TR></TABLE>
Have you adjusted the valves yet?
Old Jan 2, 2006 | 07:16 PM
98B18C1's Avatar
didnt fill up my gas tank yet...car starts and runs and rarely pops but runs very crappy...did a compression test 170 across -+5 need to do the valve adjustment 2morrow and see wat happens...the only thing im scared of is the distributor goin bad but i dont have one to swap it out
Old Jan 2, 2006 | 07:29 PM
97CWITR's Avatar
Default Re: (98B18C1)
stock head gasket? was the head milled at all?
probably a timing issue
Old Jan 2, 2006 | 07:36 PM
98B18C1's Avatar
yup genuine honda gasket..head wasnt milled just resurfaced and cleaned...maybe timing...lets just see wat happens 2morrow
Old Jan 2, 2006 | 08:00 PM
Jose-aka-Pedro's Avatar
GoodLuck man.
I just finished tearing apart me block to replace a headgasket.
Hope I'm not on here later
Old Jan 3, 2006 | 05:56 PM
98B18C1's Avatar
aight i took it to the shop and they said i dont need a valve adjustment and the timing is correct...wat da heck can be the problem thats making me run very crappy and it seems like i lost a bunch of power???
Old Jan 3, 2006 | 06:19 PM
Dogginator's Avatar
Daisy... Daisy...
How did you find TDC when you installed the timing belt?
Old Jan 3, 2006 | 10:12 PM
98B18C1's Avatar
white marking on crank pulley lined it up with the arrow marking on the timing belt cover and set cams to tdc (pointing upwards)
Old Jan 4, 2006 | 01:26 AM
Danziver's Avatar
Check your distributor and sensors, are you getting any cel's?
Old Jan 4, 2006 | 02:16 PM
98B18C1's Avatar
no CELs at all...im narrowing it down and im guessin it might be my dizzy also but car runs a little bit fine now except i feel a great lost in power wen vtec hits
Old Jan 13, 2006 | 07:58 AM
jdmsiR20's Avatar
whats your engine management setup?
check oil pressure too
Ede
May 7, 2017 04:27 PM
scotty.b16a1
Jan 2, 2013 04:54 AM
neoc03
Jan 2, 2010 10:26 PM
jonnybadboi9
Jul 15, 2009 09:39 PM
