B series Risister box
Old Dec 27, 2005 | 01:42 PM
canadamike's Avatar
Default B series Risister box
Does anyone know how to bypass the injector resister box, so I can run larger injectors. thanks Mike
Old Dec 27, 2005 | 02:29 PM
mattie_96's Avatar
if you are trying to use the saturated type of injectors that dont require a resistor box as opposed to the peak and hold type that do......then I believe that you just solder together all of the 5 wires that usually go to the resistor box...
Old Dec 27, 2005 | 02:33 PM
I Have an STD's Avatar
wrenchin'
Default Re: (mattie_96)
um, just use the stock type injectors! they are much more common anyway. use dsm 450s, they are good for 300whp, which ill tell you, is PLENTY in an EF
Brett
Old Dec 29, 2005 | 03:51 AM
canadamike's Avatar
Default Re: (I Have an STD)
thanks I run them on the street. I want to run 1000cc for the strip
Old Dec 29, 2005 | 04:26 AM
Autoworks's Avatar
Default Re: (canadamike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by canadamike &raquo;</TD></TR><TR><TD CLASS="quote">thanks I run them on the street. I want to run 1000cc for the strip</TD></TR></TABLE>
I hope you have AEM EMS or something of the sort to run the 1000cc, plus having something that needs 1000cc injectors. If not you're wasting your time and $$.
Old Dec 29, 2005 | 05:52 AM
TrueNorthStar's Avatar
Default Re: (Autoworks)
I run RC 1000cc injectors in my crx and you either need that resistor box or an injector dirver. Its hard to get them to idle lower than 1200 rpm with my AEM EMS.
I'm putting in a injector driver box while my car is down, that should help alot.
Old Dec 29, 2005 | 09:36 AM
ef2_civic's Avatar
Default Re: (TrueNorthStar)
this must be for turbo as I never had to run anything higher then 550cc on my all motor project
Old Dec 31, 2005 | 12:11 PM
canadamike's Avatar
Default Re: (ef2_civic)
I ran 750cc last year, but the thing ran so ritch I was blowing out black smoke everywhere including the track, i used MSD #pn 2064*. it also wouldn,t Idle woth a crap. I,m also runninig zdyne engine managment. Thinking of switching to uberdata, what are you using? I have a b16 built with turbo and nitrous. car runs great on dyno but shitty at track. also have clutch question. I have a nopi 4 puck race clutch, worked good on dyno. just spun at the trak. what whould you use? its putting down 520 to the wheels.
thanks mike
Old Dec 31, 2005 | 01:02 PM
wrenchin'
congrats, you make to much power for a regular clutch. ur gonna need a twin disk. exedy makes a great one. to bad they are like $1100!! every once in awhile u can find them on sale for 950-1000. good luck!!
Brett
Justin Olson
Jul 30, 2008 09:03 AM
LSej1
May 20, 2008 09:13 PM
Midori Green
May 19, 2007 05:45 AM
Seraph0
Nov 24, 2003 01:18 AM
hybridreams
Sep 12, 2003 09:22 PM
