Setting timing without cover
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by extrmeboost »</TD></TR><TR><TD CLASS="quote">The jackass I got my motor from sold it without a lower timing cover and I need to set the ignition timing, is there a way? and yes I searched. </TD></TR></TABLE>
You mean the mechanical timing?
I had this same problem with mine not having a cover you can set the cam gears and then take the spark plug out and put a long screw driver or whatever you want down in there and turn the crank pulley till its at the highest point that is TDC. it takes a couple trys but I did it with my LS and then you can do the rest with the ECU
mugenwannabe
Apr 1, 2007 07:03 PM
