IS THERE A DIFFERENCE BETWEEN LS AND GSR REAR MOTOR MOUNT
Old Dec 27, 2005 | 12:00 PM
mattssi's Avatar
Default IS THERE A DIFFERENCE BETWEEN LS AND GSR REAR MOTOR MOUNT
Like the title said. Is there a difference? I need a rear motor mount, and i was told there is a difference. like the ls one will come up short towards the bottom of the mount
Old Dec 27, 2005 | 12:09 PM
Stoich EG2's Avatar
Default Re: IS THERE A DIFFERENCE BETWEEN LS AND GSR REAR MOTOR MOUNT (mattssi)
i don't know if there's a difference but i know you'll be fine with either one
Old Dec 27, 2005 | 12:17 PM
mattssi's Avatar
Default Re: IS THERE A DIFFERENCE BETWEEN LS AND GSR REAR MOTOR MOUNT (ADVAN EG2)
I was told that the ls differ's with the 2 19mm bolts. you will be able to get 1 in, but not the other, like the bottom one. And i am not really okay with having only one in there. Can i get a confirmation that they are the same or not?
Old Dec 27, 2005 | 12:20 PM
philosofy1's Avatar
if its just the mount you are talking about, then no there is no difference
Old Dec 27, 2005 | 12:26 PM
mattssi's Avatar
Default Re: IS THERE A DIFFERENCE BETWEEN LS AND GSR REAR MOTOR MOUNT (philosofy1)
Yeah, just the rear mount. I just want to make sure that it is the same as the gsr mount. The ls ones are easier to come by around here. And if they are the same then i will just get one of those? ?
Old Dec 27, 2005 | 12:43 PM
Hybrid96EK's Avatar
Exactly the same.
Old Dec 27, 2005 | 12:51 PM
mattssi's Avatar
Thanks!! Thats all i needed!
Old Dec 29, 2005 | 08:32 AM
mattssi's Avatar
So i got my hands on a rear t mount bracket from a 98 ls i think it was. And the 2 19mm bolt spacing is differn't. There is about a 1/2" spacing difference. So i guess they're not the same after all.
Old Dec 29, 2005 | 09:56 AM
Stoich EG2's Avatar
Default Re: (mattssi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by someone &raquo;</TD></TR><TR><TD CLASS="quote">For the rear mount you will need to use a 1994-2001 Integra rear bracket. The actual rubber mount that bolts to the rear subframe can be the stock civic one or the Integra one.</TD></TR></TABLE>
all integras should bolt on the same...
Old Dec 29, 2005 | 10:22 AM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattssi &raquo;</TD></TR><TR><TD CLASS="quote">So i got my hands on a rear t mount bracket from a 98 ls i think it was. And the 2 19mm bolt spacing is differn't. There is about a 1/2" spacing difference. So i guess they're not the same after all. </TD></TR></TABLE>
Incorrect. They are all the same. Unless you scored one from an auto. The manual mounts are ALL the same. This I know for a fact.
Old Dec 29, 2005 | 11:56 AM
mattssi's Avatar
Default Re: (Hybrid93Eg)
That has to be it then.. It came off an automatic. That is weak. Yeah, it doesn't fit right. So does that mean if i try to use it, it will not line up correctly? I mean, I can get it to bolt up to the top part of the tranny, one of the 19mm bolts, and then the rear crossmember mounting point. the only bolt that will not go is the bottom 19mm. Can i get away with just using 1??
Old Dec 29, 2005 | 12:04 PM
Stoich EG2's Avatar
the idiots that put my motor in before i bought my car did that. in fact, they were only using 2 of 4 rear mount bolts, 1 starter bolt, and 2/3 tranny mount bolts/stud/nut. It wasn't exactly safe i'd say but it worked for me for a while. I did, however, feel alot of jerking from the engine when i shifted hard.
Old Dec 29, 2005 | 12:08 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattssi &raquo;</TD></TR><TR><TD CLASS="quote">That has to be it then.. It came off an automatic. That is weak. Yeah, it doesn't fit right. So does that mean if i try to use it, it will not line up correctly? I mean, I can get it to bolt up to the top part of the tranny, one of the 19mm bolts, and then the rear crossmember mounting point. the only bolt that will not go is the bottom 19mm. Can i get away with just using 1?? </TD></TR></TABLE>
Its not the correct mount. Thats not to say you can't rig it to work, but you should use a manual tranny mount.
Old Oct 21, 2016 | 05:26 PM
c4x's Avatar
c4x
Hi. I have a integra gsr 95 and also need to change the rear motor mount. Can i use the same civic vti b16 rear engine mount? We dont have acuras stores in Brasil. Thanks a lot!
WeAreIntegrated
Oct 9, 2010 09:50 AM
dc2jdmteg05
Jul 18, 2009 06:06 PM
aaronhume
Mar 29, 2007 09:02 PM
scartail
Dec 5, 2006 07:07 PM
chuckieD
Dec 4, 2005 11:02 PM
