94+ Integra gurus ... I got unknown wires on my shell.
I got a shell and I have a few sets of wires that I do not know what they go to. I took pictures of them, so please help if you can.
Set A: These two wires are located around the rear seat area.
Set B: these connectors are near the roof by the driver side
Set C: is this the only connector that goes to the fuel pump?
Set D: this two wires in the door frame and connect to the door controls, they are cut.
Set E: these wires are comming off from back of the dash
Set F: it looks like something goes here, maybe a door seal or a plastic piece?
Set G: these wires are comming off the back hatch.
please use 'Set X' when describe the wires function.
Thanks,
Nick
Thanks,
Nick
I think your pics are a little jumbled, but the wires on the hatch go to the third brake light which you have had removed, the last pic, set G I think
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sooo_slow »</TD></TR><TR><TD CLASS="quote">Set A: most likely speaker wires
Set F: weather stripping should go there
All I can really help with I have a 93 .</TD></TR></TABLE>
Are you sure Set F is weather stripping? It is hard plastic. I thought the weather stripping was on the edge of the door itself.
