REAR BUMPER AND BACK SEATS!!!!
Old Dec 27, 2005 | 11:49 AM
SlAmMeD 91 HaTcH's Avatar
Default REAR BUMPER AND BACK SEATS!!!!
Can some one tell me how to remove the Rear bumper and rear seats in a 1991 honda civic hatch..?>?
Old Dec 27, 2005 | 03:37 PM
classic69's Avatar
Default Re: REAR BUMPER AND BACK SEATS!!!! (SlAmMeD 91 HaTcH)
try a car manual
Old Dec 27, 2005 | 03:53 PM
Proper's Avatar
Default Re: REAR BUMPER AND BACK SEATS!!!! (classic69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by classic69 &raquo;</TD></TR><TR><TD CLASS="quote">try a car manual </TD></TR></TABLE>
^best advice.... But as far as the rear seat... all it is, is a bolt on the bottom near the center of the seat... then two clips at the pivot point on the sides and taadaa!!! the seat is out. But seriously... if the rear seat removal is that difficult for you to figure out then a helms manual is a must for any other adventures to plan to pursue with your EF....But there is only one way to learn, and that is to jump in and figure it out! Good Luck
-Proper
Old Dec 28, 2005 | 08:00 AM
No one knows how to take of the rear bumper...?
Old Dec 28, 2005 | 03:39 PM
???????????????????????????? come on now..
Old Dec 28, 2005 | 03:47 PM
Zaakro's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlAmMeD 91 HaTcH &raquo;</TD></TR><TR><TD CLASS="quote">???????????????????????????? come on now..</TD></TR></TABLE>
there is 2 nuts on the inside of the car and 2 nuts on the outside, I believe they are 12mm
Old Dec 28, 2005 | 03:50 PM
crux131's Avatar
Well, on a crx....not sure if it is the same on a hatch...
Remove the 4 screws going into the bumper cover on the back of the fenderwell ( outside the car, can be seen behind the tire ).
Remove hatch cover, remove cover over spare tire, look for 2 nuts in the back corner above the back of the bumper.
Get under car, remove the other 2 nuts from the back of the bumper ( should be pretty much directly under the 2 on the inside ).
unhook tag light wiring, and double check for anymore various clips.
You might have to remove some of the trim on the back hatch wall to uncover the nuts....not sure
You may also have to remove some of the splash guards....but I don't remember having to do that.
Good luck, and get a manual...it's a good investment.
Old Dec 28, 2005 | 03:56 PM
temp's Avatar
Default Re: REAR BUMPER AND BACK SEATS!!!! (crux131)
2 words
VERY CAREFULLY
Old Dec 29, 2005 | 03:02 PM
Zaakro's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crux131 &raquo;</TD></TR><TR><TD CLASS="quote">Well, on a crx....not sure if it is the same on a hatch...
Good luck, and get a manual...it's a good investment.</TD></TR></TABLE>
its the same on a hatchback
SOHCVTEC
Honda CR-V & Element
Mar 24, 2018 02:25 PM
ednyboo
Oct 29, 2006 08:32 PM
ralpheezy
Sep 17, 2004 09:45 PM
Nocturnal
Jan 7, 2003 11:42 AM
Turtle
Oct 4, 2001 08:23 AM
