SCCA Suspension Set Up Feedback
Old Dec 27, 2005 | 10:22 AM
AUTOX Junkie's Avatar
Default SCCA Suspension Set Up Feedback
What kind of suspension setting suggestions do you guys have out there for SOLO II?
All feedback is greatly appreciated.
Currently running:
Tein RA's. 3clicks to full stiff F&R
Kumho Victor Racers
Still need to corner balance, but running coil overs raised 2" from bottom in the front, and 2.3" up from bottom in the rear.
TP- 28PSI F and 25PSI R
All upper strut bars / A Pillar etc.
Adding Type R Sway Bar once I find some endlinks.
Thanks,
Lar
Old Dec 27, 2005 | 11:27 AM
littleredcivic's Avatar
each course will have a different setup. you will have to work between your runs to find a good car for each course. your alignment is what can also make a big difference. for me, i use toe out .02 in the front and toe in .02 in the back. front camber at -1.75 and rear camber at -2.75. on direzza, the car is entry driftable and point and gas after that. i use omni power 10/8 at max height in the rear and the front is leveled with it.
Ohmega
Suspension & Brakes
May 5, 2015 04:46 PM
BoostThisMS
May 3, 2013 10:33 AM
tallkan
Mar 31, 2009 07:54 AM
RIP V8s
Suspension & Brakes
Nov 3, 2005 03:41 PM
JunIntegra
Nov 17, 2004 11:49 AM
