Soft Clutch Pedal...
This morning when i got into my car, I noticed my pedal was very soft.. almost no pedal.. it had very little pressure. Enough pressure for me to get in and out of gears. after driving around it was back to normal.. sometimes after hard driving the pedal goes extremly soft again.. so its kinda of a off and on problem...
i already checked the clutch slave for leaks, and bleed the system but still having the problems...? any ideas...?
if this helps... 93 DX, EX tranny, Exedy clutch.
TIA
TIA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by underb00steg6 »</TD></TR><TR><TD CLASS="quote">check the master cylinder???
already checked... no visible leaks and full of fluid...
</TD></TR></TABLE>already checked... no visible leaks and full of fluid...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicky »</TD></TR><TR><TD CLASS="quote">soft like a natural breast? How old is your clutch?</TD></TR></TABLE>
hahaa...! i put in the Exedy less then a year ago...
its kinda odd... if i drive low rpms the pedal feels normal but once i hit boost my pedal feel soft liek a natural breast haha..
that is what my clutch felt like before it broke. when i removed the gearbox, i found a loose spring and a broken piece of the clutch inside. i have also had that happen right before my slave cylinder broke...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by littleredcivic »</TD></TR><TR><TD CLASS="quote">that is what my clutch felt like before it broke. when i removed the gearbox, i found a loose spring and a broken piece of the clutch inside. i have also had that happen right before my slave cylinder broke...</TD></TR></TABLE>
maybe i should just go and replace my slave cylinder then...
Scotty Dosent Know
May 31, 2009 04:53 AM
JimmyAtlantis
Jun 2, 2006 08:55 AM
