Broken Connecting hose.
Just like the title says.
I have just discovered that the cause of my coolant leak is coming from the connecting hose that runs from under the intake manifold, into the thermostat housing. When I looked it was completly out, with a broken O-ring and coated with what seemed to be grease.
Anyway, I need to reseal it. What would you guys recommend to do it with??
Modified by Jeffrey9 at 11:09 PM 12/26/2005
So just the O-ring should hold?
...I'm assuming when you say the same work, this was on the same metal hose the plugs into the thermostat housing?
Thanks.
Thanks.
