Suspension Advice needed
I am going to be ordering a Beaks Anti-Sway Bar and a ASR Subframe reinforcment kit to prevent tear outs and eventually will get Koni Yellow shocks all around and was wondering what would be some good springs to go w. the yellows I am looking to drop it a bit and impove handling ( I am in NYC so potholes might be a small issue nothing crazy)
Thanks!
Thanks!
I'm running the OTS Koni's and Ground Control Coilovers. Its definetly a great improvement on handling and the koni's can handle a good drop. I've had the car in staten island now for on and off two years now with 4 road trips going home to miami and haven't had a problem yet. I would just recommend the ots spring rates. If you want it to be stiffer or softer just adjust the koni's.
Ali
Ali
Is this the ones your talking about? http://cgi.ebay.com/ebaymotors...ZWDVW
and these for rear koni http://cgi.ebay.com/ebaymotors...ZWD1V
and these front koni http://cgi.ebay.com/ebaymotors...ZWD1V
Thats about a 750-800 buck setup does it sound OK?
When you order the ground control coilovers, order them for koni's. For example, http://www.nolimitmotorsport.c....html under the shock colum 4 represents konis. If you scroll down you'll see what numbers represent what.
Look in the sponsor section, 800 bucks seems right.
Ali
Ali
Philbert
Aug 30, 2001 09:46 PM
