CTR Pistons handle a 50 shot?
Old Dec 26, 2005 | 06:03 PM
totsie7944's Avatar
Default CTR Pistons handle a 50 shot?
I need to do more research, but I am throwing around the idea of spraying a 50 shot on my R, but I have heard that the CTR pistons can have some issues with spray. Any advice?
Also, I wanna buy a SMSP multi-piece header soon, how much do you guys think I could get for my JDM 4-1 header with a minor dent/scrape in the bottom?
Old Dec 27, 2005 | 07:18 AM
totsie7944's Avatar
Default Re: CTR Pistons handle a 50 shot? (totsie7944)
anybody have input?
Old Dec 27, 2005 | 08:04 AM
Bradstard's Avatar
Personally, I wouldn't spray on Toda Spec C's...
Old Dec 27, 2005 | 11:36 AM
Used2beAb16's Avatar
Default Re: CTR Pistons handle a 50 shot? (Bradstard)
wouldnt worry as much about the toda spec c's as much as i would the big compression from those pistons and they arent forged.
Old Dec 27, 2005 | 11:59 AM
JUMPDADDY's Avatar
Default Re: CTR Pistons handle a 50 shot? (Used2beAb16)
I woulnd't spray at all on ctr's. Too much compression, you'll eventually blow a hole straight through the piston.
Old Dec 27, 2005 | 06:42 PM
92eg6's Avatar
Default Re: CTR Pistons handle a 50 shot? (JUMPDADDY)
i was gonna ask the same thing, since i already melted a piston on a b16....jus get some forged pistons.
Old Dec 27, 2005 | 10:22 PM
totsie7944's Avatar
Default Re: CTR Pistons handle a 50 shot? (92eg6)
ok then no spray for me. Thanks for your help guys.
Old Dec 28, 2005 | 07:19 AM
92eg6's Avatar
u would think a melted piston would stop me from sprAYINg.....guess again, but this time im throwin in some forged pistons, would love t0 go turbo but i need a daily driver for at least another two years so its not for me but spray is
Old Jan 13, 2006 | 10:21 PM
kidrolla's Avatar
the motor im working on know i plan on runing a 150 to 250 shot
Old Jan 14, 2006 | 12:02 AM
rjay8604's Avatar
Default Re: CTR Pistons handle a 50 shot? (kidrolla)
I'm pretty sure if you set it up right you can run a 50 shot on cast pistons. I'm no nitrous expert, but as long as there is properly retarded timing and the Air/fuel ratios are setup, and the nitrous spray is setup up properly, it would be no different than gaining 50 hp NA on cast pistons.
Old Jan 14, 2006 | 12:06 AM
sheepey's Avatar
bring the lobe centers closer aswell...that will help a little....
Old Jan 14, 2006 | 12:29 AM
rjay8604's Avatar
Default Re: (sheepey)
I also have theory on nitrous as well, pertaining to the "retention" of the nitrous shot and the cams. The nitrous is inducted into the engine exactly how the air is, when the engine is in its optimal VE range, it is retaining the most of the intake charge it can, therefore as long as the nitrous is released during the engines optimal VE range, the nitrous will be in the controlled combustion environment and will also have the greatest benefit in this range. We know most of the honda engines we deal with have the highest VE range in the 6500rpm and up depending on the build. Just my 2 cents.
getzy3
Dec 13, 2004 10:58 PM
GQ 05YellowEVO8
Aug 30, 2002 03:12 PM
mugenintegra16
Jun 9, 2002 05:49 PM
GQ 05YellowEVO8
Jan 12, 2002 09:38 PM
powerfulperformance
Aug 27, 2001 04:36 AM
