d16z in my 88 crx si
Did you get the obd-0 to obd-1 distributor harness conversion?
Make sure there is continuity in the wires. Resolder the connections. Replace the cap and rotor.
no i didnt get the dizzy conversion harnesses . there is continuity but on the paper rywire send with their conversion harnesses it says u have to switch 2 wires and i did that . and yet agian got nothing.
did you ground all the yellow wires from the injectors when you switched to obd-1 i had the same problem mine would crank and i had spark but no gas! so i go into the harness and found the ground wires from the old dual point injectors and grounded them and my car started right up....so maybe you should check that out i was pissed cus i forgot about those two freaking wires within the harness hope that helps
So you pinned on OBD1 plugs? or you're actually trying to run a OBD0 Distributor (which will never work)... clarify that for me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NikoZai »</TD></TR><TR><TD CLASS="quote">So you pinned on OBD1 plugs? or you're actually trying to run a OBD0 Distributor (which will never work)... clarify that for me
True, I'm still pre obd on my z6.
When I did the swap and wasn't getting any spark, it turned out that the set screw on the rotor came out in the dizzy. If the dizzy is all bolted up to the motor, you have the cap off, and can turn the rotor, your missing the screw. No rotor spinning, no spark. Hope this helps you. Good luck with your swap.
</TD></TR></TABLE>True, I'm still pre obd on my z6.
ive had the obd 1 dizzy hooked up with the jumpers and yet no spark . thats wat i dont get. sso today im goin to work on it a little bit and run the ten extra wires that rrywire says you have to and put the obd1 distributor back on and see where that gets me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by savagecrxsi »</TD></TR><TR><TD CLASS="quote">ive had the obd 1 dizzy hooked up with the jumpers and yet no spark . thats wat i dont get. sso today im goin to work on it a little bit and run the ten extra wires that rrywire says you have to and put the obd1 distributor back on and see where that gets me
Ok, so you have the obd1 dizzy and injectors. What about the ecu? Are you still using the pm6? Try a obd0-obd1 jumper and a p28.
</TD></TR></TABLE>Ok, so you have the obd1 dizzy and injectors. What about the ecu? Are you still using the pm6? Try a obd0-obd1 jumper and a p28.
cherroneballs
Jun 1, 2010 07:30 AM
panaphobic
May 6, 2008 01:18 PM
white90rexsi
Jun 21, 2007 01:32 PM
