Skunk 2 intake manifold install on a B18C1....please help????
Like the post says, I'm getting the Skunk 2 intake manifold for my 97 GSR hopefully next week. I'm keeping my OEM GSR throttle body...my question is, what other hardware do I need to install this correctly? I'm doing the installation myself after hours at my job. I talked to someone and they told me to just get the throttle cable and bracket from an ITR have the throttle plate linkage work properly so I'm buying that this week...but like I said, what other hardware do I need as far as hoses and bracketry goes? Would it be no problem installing all the factory sensors back on to the manifold? Do i have to eliminate any sensors or hoses? Or should I just take my car to shop and let them do it?
https://honda-tech.com/zerothread?id=1141806
Here you go. Blox install but its the same exact setup.
when i install my blox IM i had to buy new studs because the ones that was on my car was too short, i also install a hondata intake manifold gasket so maybe that's why the studs were too short, and u wont be able to use all the sensor's on the new intake manifold i had to bypass mines.
perseverance
Oct 31, 2006 10:15 PM
