Need Help!!!! Pics inside....
Old Dec 26, 2005 | 03:19 PM
MiamiEJ1's Avatar
Default Need Help!!!! Pics inside....
f
Modified by MiamiEJ1 at 10:30 AM 2/2/2007
Old Dec 26, 2005 | 03:35 PM
ekcivic9's Avatar
easy out maybe? can u try to cut a slit into it so you can use a regular phillips head screwdriver?
Old Dec 26, 2005 | 03:38 PM
meat.'s Avatar
Default Re: (ekcivic9)
Impact Gun. Works for me every time.
Old Dec 26, 2005 | 03:53 PM
MiamiEJ1's Avatar
Default Re: (ZeroEF9)
umm.... any more suggestions.. dont really have an impact gun
Old Dec 26, 2005 | 04:04 PM
FalkenSiR's Avatar
Default Re: (MiamiEJ1)
Take the damn thing to a shop and tell them to take it out. Now the hard part: Do you have $5?
Old Dec 26, 2005 | 04:11 PM
WHORE: JDMCoveralls's Avatar
Default Re: (fast88std)
I done this before, then i busted out the impact tho... Works like a charm... I would most likely take it to a shop tho and tell them to take it out...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZeroEF9 &raquo;</TD></TR><TR><TD CLASS="quote">Impact Gun. Works for me every time.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast88std &raquo;</TD></TR><TR><TD CLASS="quote">Take the damn thing to a shop and tell them to take it out. Now the hard part: Do you have $5?</TD></TR></TABLE>
What does he need 5$ for?
And remember boys and girls...
JDMatters
Old Dec 26, 2005 | 04:12 PM
MiamiEJ1's Avatar
Default Re: (JDMatters)
k...guess i'll take it to a shop.. anyone know any shops around south florida?
Old Dec 26, 2005 | 04:13 PM
Phone Book?
Old Dec 26, 2005 | 05:35 PM
T.J.'s Avatar
Default Re: Need Help!!!! Pics inside.... (MiamiEJ1)
Your going to need an impact gun now.
Old Dec 26, 2005 | 05:36 PM
Lmgrcivic's Avatar
The 5 bux is to pay the shop but most of the time they will do it for free will take them 2 mins to have it off and everything
Old Dec 26, 2005 | 05:47 PM
DelSolDon's Avatar
Default Re: (Lmgrcivic)
WOAH dude, slow down. you don't need to mess with that until you take the entire spring/ shock assembly out of the car. take those 2 14mm nuts off that are on either side of the part your fu*%ing with. then, when you get the entire assembly pulled from the car, put a spring compressor on the spring, crank it down as far as you can get it, then try to get that nut loose. if at that point, you still can't get it off, (if you are replacing the shocks, which you should be anyway) just put some vice-grips on the shaft for the shock to hold it still while you turn on that nut on top.
Old Dec 26, 2005 | 06:04 PM
spoonsports12's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MiamiEJ1 &raquo;</TD></TR><TR><TD CLASS="quote">k...guess i'll take it to a shop.. anyone know any shops around south florida? </TD></TR></TABLE>
u sound totally helpless... in this case, put down the tools and stop workin on ur car....
Old Dec 27, 2005 | 01:44 AM
97spooncivic's Avatar
Default Re: (DelSolDon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DelSolDon &raquo;</TD></TR><TR><TD CLASS="quote">WOAH dude, slow down. you don't need to mess with that until you take the entire spring/ shock assembly out of the car. take those 2 14mm nuts off that are on either side of the part your fu*%ing with. then, when you get the entire assembly pulled from the car, put a spring compressor on the spring, crank it down as far as you can get it, then try to get that nut loose. if at that point, you still can't get it off, (if you are replacing the shocks, which you should be anyway) just put some vice-grips on the shaft for the shock to hold it still while you turn on that nut on top.</TD></TR></TABLE>
EXACTLY, you dont wanna take that off just yet, dont hurt yourself! If you did it like stated above it probably wouldnt have stripped.
Old Dec 27, 2005 | 07:40 PM
MiamiEJ1's Avatar
Default Re: (97spooncivic)
i did remove the shock... and compressed it with a spring compressor and then try to take the nut off after loosening it... I just put the shock back on because i had to move the car. But w/e I already took it off. Thanks for the help though.
Old Dec 27, 2005 | 08:20 PM
JDM-EJ1's Avatar
More or less, or vice grips.
Old Dec 27, 2005 | 08:33 PM
blackdelslo's Avatar
Default Re: (JDM-EJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">just put some vice-grips on the shaft for the shock to hold it still while you turn on that nut on top. </TD></TR></TABLE>
Finally someone who knows what their talking about.
GiT LaO'd's Avatar
vice grips for sure....but make sure you cover the stem of the shock...You dont want any imprints on it...
A.S.I.M.O
Nov 18, 2006 04:53 AM
coot_er
Dec 1, 2005 10:30 PM
life sux die
Sep 16, 2004 02:59 PM
Declectic
24
Jul 21, 2004 09:21 AM
PY01ITR42
May 18, 2004 10:50 AM
