Where Do You Get Del Sol DOHC VTEC Shift linkage?
Old Dec 26, 2005 | 12:45 PM
hotimportcrx's Avatar
Default Where Do You Get Del Sol DOHC VTEC Shift linkage?
Does anyone know where to get aftermarket del sol dohc vtec shift linkage? I called hasprt but they dont make it....and i've seen it on the internet for about 200$ a while back...but thats overpriced for shift linkage.
Old Dec 26, 2005 | 12:54 PM
nocturnaldragon's Avatar
Default Re: Where Do You Get Del Sol DOHC VTEC Shift linkage? (hotimportcrx)
If your good with a welder you can make your own, other wise the junkyard would be your best bet.
Old Dec 26, 2005 | 12:57 PM
losder riper's Avatar
honda dealer get just the rods 120 tops
Old Dec 26, 2005 | 02:51 PM
eg6ajk's Avatar
just get a new one from honda or get a DA/DC linkage and cut/weld
http://www.hondaautomotivepart...LEVER
Old Dec 26, 2005 | 02:55 PM
Default Re: Where Do You Get Del Sol DOHC VTEC Shift linkage? (eg6ajk)
yeaa i guess im just gonna get it from majestic honda
Old Dec 27, 2005 | 09:04 AM
ilovemyeg's Avatar
in line four sells stock del sol b16 shift linkages
Old Dec 27, 2005 | 09:13 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Where Do You Get Del Sol DOHC VTEC Shift linkage? (ilovemyeg)
i think i got the last set for likr 80- 90 bucks.
Old Dec 27, 2005 | 10:29 AM
Del Sol SiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hotimportcrx &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone know where to get aftermarket del sol dohc vtec shift linkage? I called hasprt but they dont make it....and i've seen it on the internet for about 200$ a while back...but thats overpriced for shift linkage.</TD></TR></TABLE>
why get aftermarket when you can get oem ???
http://www.slhonda.com
#13 54201-SR2-G03 ROD, GEARSHIFT $46.04
Old Dec 27, 2005 | 10:54 AM
mattssi's Avatar
if you know somebody that works at a honda dealership it is about 80 bucks. That is including the rubber piece ion the stabalizer bar!
nacivicsi
Aug 14, 2012 05:45 PM
SOLvtec
Oct 27, 2006 09:30 AM
lovitalracer
Feb 14, 2005 07:49 PM
teawoboba
Jun 3, 2004 06:44 AM
b18bcivic
May 27, 2004 08:54 AM
