need opinions on which block i should use w/ my FULLY built head?
Old Dec 26, 2005 | 11:21 AM
jdmjeff's Avatar
Default need opinions on which block i should use w/ my FULLY built head?
well i just got a JG port and polished head... here's what she has:
b16 (pr3) head
FG full port and polished
3 angle valve job
FG stainless steel valves
rocket m/sdual vavle springs
rocket m/s titanium retainers
AEM cam gears
Skunk2 stage 2 cams
I was running a gsr block but i spun 3 rod bearings and now shes up for sale! the motor is going in a 94 integra so i would like a lil more torque but what block w/ mild motification should i run w/ that head? THANKS
Old Dec 26, 2005 | 11:23 AM
scUba-stEve's Avatar
Default Re: need opinions on which block i should use w/ my FULLY built head? (jdmjeff)
if that's still my head jeff...it actually has rocket motorsports springs/retainers...but what happened man?...did you get the valves fixed?
jdmjeff's Avatar
Old Dec 26, 2005 | 11:24 AM
jdmjeff's Avatar
Default Re: need opinions on which block i should use w/ my FULLY built head? (zer0-psi)
yeah the head is fixed but NOW (with my luck LOL) i have 3 spun rod bearings so shes gonna be down for a while! now im looking for a new block but im not sure what block i wanna go w/
Old Dec 26, 2005 | 11:32 AM
jdmjeff's Avatar
Old Dec 26, 2005 | 05:25 PM
jdmjeff's Avatar
Old Dec 27, 2005 | 12:38 AM
fmrprojects's Avatar
stick a ls crank in the gsr block with some ls rods and pr3 pistons. that should be hot
Old Dec 27, 2005 | 08:05 AM
Bradstard's Avatar
Default Re: need opinions on which block i should use w/ my FULLY built head? (fmrprojects)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects &raquo;</TD></TR><TR><TD CLASS="quote">stick a ls crank in the gsr block with some ls rods and pr3 pistons. that should be hot</TD></TR></TABLE>
Sounds good to me. I would go with forged rods/pistons instead of OEM.
Old Dec 27, 2005 | 09:09 AM
clint g's Avatar
Default Re: need opinions on which block i should use w/ my FULLY built head? (Bradstard)
bump up for the homeboy
Old Dec 27, 2005 | 09:47 AM
Michael Delaney's Avatar
Default Re: need opinions on which block i should use w/ my FULLY built head? (clint g)
99 bottles of beer on the wall....
everybody join in...
Old Dec 27, 2005 | 10:03 AM
Default Re: need opinions on which block i should use w/ my FULLY built head? (Michael Delaney)
yeah...since you spun the bearings, the crank is either bad, or you'll need to machine it...so if i were you, i'd go find an LS crank/rods, and throw your ctr pistons on that...your compression will be in the 12's or so, but that's perfect for those skunk2 cams you have...good luck...and keep me updated on how you do.
Old Mar 27, 2006 | 10:48 PM
grtek's Avatar
damn man I'm in the same boat as you, I just fixed my head and now one of my rod bearings went out. Another 2g's into my car.
K PORT
Northeast (Sales)
Nov 23, 2012 07:16 AM
turbo24
Oct 31, 2011 10:13 PM
B18T3T4
Jun 3, 2007 07:47 PM
mportbusta
Apr 28, 2006 01:02 PM
