type R fuel pressure
i am trying to tune my fuel pressure with a aem fuel rail and regulator
can someone please help me out ??
i don't know what the stock pressure should be, therefore i can't judge what i should set it at it is currently at 52 psi is this right? if not what? IS right!!
thanks guys!!!
i do have a 5zigen exaust, but forgive my ignorance, but i dont know what the vacume line does and wich way is it better on or of??
[Modified by macdaddy, 6:11 PM 3/18/2002]
With your set-up there is not really a need to set the fuel pressure higher. If you had a good header, high flow cat. conv. and less restrictive exhaust you might run a little lean. But right now you wont gain anything with a higher fuel pressure.
you set your fuel pressure lower then stock and got your best results
just curious cause i have the same setup
intake, headers, high flow, cat back, VAFC I also have TB and Intake manifold
What is you VAFC settings if your at 44psi
Correct me if I'm wrong but don¡¦t the ECUs closed loop 02 readings compensate for different fuel pressures?
It has been posted in other threads that even under WOT the ECU will apply a correction factor that is derived from 02 observations under closed loop. This effect would essentially eliminate any effects changing the fuel pressure might have under all load conditions.
[Modified by JPP, 9:45 AM 3/19/2002]
I agree that the computer can only correct up to a certain point. I don't agree with the O2 compensating during open loop at WOT. I have read that during open loop, only air metering sensors are used to determine fuel. O2 is left out of the measurements. Also when the ECU reaches it's maximum correction factor and it senses a leaning condition. As the leaning condition continues or increases, the motor creates knock and the knock sensor tells the ECU to pull some of the timing out.
What do you guys/gals think of this?
Stock fuel pressure reading ratings are fairly open, between 47 and 54psi. Is it possible that this wide range of stock fuel pressures could account for the most of the power differences between weaker and stronger stock Rs?
If the WOT fuel curves are not effected by any parameters that could be learned by the ECU during closed loop operation (as stated earlier), then it would seem that this wide fuel pressure range could account for measurable differences in engine performance between cars. We know that changing fuel pressures by 2psi can have measurable effect on an engines performance.
This could be an important question for those who suffer with weaker cars and are looking for the cure. Perhaps it lies in the fuel pressure?
Regards,
Regards,
Regards,
Regards,
Another possibility is that the WOT fuel curve is program in such a way that you will not run lean (on a stock set-up) if the fuel pressure is in the operating range of 47 PSI to 54 PSI.
Just toughts to consider
I don't think think you can say the power difference between 2 stock ITR is totally based on the fuel pressure difference. But it should have something to do with it.
I guess we can make a conclusion on this unless we can get a few stock ITR and dyno test them with a FPR alone!!
Yes it would be nice to know exactly what that little box does (maybe I should go work for Honda)
Hopefully, in a few years, we will be able to download the ECU program on a CD, and by working on a virtual dyno on our personal computer we will be able to reprogram every parameter an get 220 WHP.
Then again I might win 10000000$ at the next 6/49 drawing.
poodlemuffer
Engine Management and Tuning
Feb 1, 2014 09:24 AM
