Suspension & Brakes Theory, alignment, spring rates....
GSR rear sway bar onto a 96-00 civic... will it fit?
Old Dec 26, 2005 | 06:52 AM
fireant's Avatar
Default GSR rear sway bar onto a 96-00 civic... will it fit?
Specifically, I need to know if the GSR D-brackets are compatible with the 96-00 civic's rear subframe.
Old Dec 26, 2005 | 07:49 PM
gabebauman's Avatar
Default Re: GSR rear sway bar onto a 96-00 civic... will it fit? (fireant)
They should work...as long as you have the other two brackets that connect to the subframe and the 99-00 si endlinks.
Looks like this:
Old Jan 8, 2006 | 02:09 PM
SprayinCX's Avatar
i have one si endlink but i am not sure if it is right or left. it has a R on it. so i think it is the right side. i am guessing that would be the passenger side?
i have a itr rear sway bar also. so i guess my question on this topic is all i need the the subframe plates and the left endlink and all this should fit?
Old Jan 9, 2006 | 08:57 AM
nonsense's Avatar
Default Re: GSR rear sway bar onto a 96-00 civic... will it fit? (SprayinCX)
If you're putting an ITR bar on an Ek you should really look into subframe reinforement. You don't want to have your subframe rip out. Look into comptech's subframe brace and http://www.a-spec-racing.com too (although a-spec doesn't seem to be answering my emails, so I don't know if they're still making them??)
Old Jan 9, 2006 | 09:00 AM
alwaysoverkill's Avatar
yeah, 22mm (USDM) or 23mm JDM) ITR rear sway bar = subframe reinforcement a must or you'll tear the **** out of it and pay out the ***.
Beaks kit is minimum, ASR or Comptech is the best option.
GSR rear sway bar, you don't need subframe reinforcement since it comes that way from Honda stock (13mm on SI, GSR is 14mm)
PS. civicferio I beleive is Charleston screen name on here, IM him and he replies fast. I sent him an IM christmas eve and got a fast reply.
ASR is $180 plus shipping
Old Jan 9, 2006 | 05:33 PM
SprayinCX's Avatar
Default Re: (alwaysoverkill)
yea i forgot to mention it was a US itr. who sells the comptech. i do like the asr one.
Old Jan 10, 2006 | 07:40 AM
nonsense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alwaysoverkill &raquo;</TD></TR><TR><TD CLASS="quote">PS. civicferio I beleive is Charleston screen name on here, IM him and he replies fast. I sent him an IM christmas eve and got a fast reply. </TD></TR></TABLE>
I guess I emailed the wrong guy at ASR then LOL . I sent the first email on Jan 4th and the second on Jan 6th and still no reply.
Old Jan 10, 2006 | 09:57 AM
PIC Performance's Avatar
Default Re: (nonsense)
I remember reading that he has been out of town (or out of the country) recently.
Old Jan 10, 2006 | 10:08 AM
BryanPendleton's Avatar
Read this!
http://www.suja1.com/tech2.html
Old Jan 31, 2006 | 09:42 AM
patdow1's Avatar
Default Re: GSR rear sway bar onto a 96-00 civic... will it fit? (BryanPendleton)
Quick question, I just recently purchased a GSR rear sway bar but it didn't come with the bolts/nuts on the inner most part of the "D Brackets" does anybody know what the bolt diameter and length is and grade of bolt used? As I will be paying a visit to Home Depot for them.
Old Jan 31, 2006 | 10:51 PM
EeeJayEight's Avatar
Default Re: GSR rear sway bar onto a 96-00 civic... will it fit? (patdow1)
i forget what the grade is but home depot doesnt carry them.. i think people have reccomended grade 8 i think.. but i dont know..
from what i remember suspension bolts require a grade higher than HD carries.
i am not sure tho...however.. if u do get parts at HD.. get the highest grade bolt they carry in that size
Old Feb 1, 2006 | 07:26 PM
patdow1's Avatar
Default Re: GSR rear sway bar onto a 96-00 civic... will it fit? (EeeJayEight)
EeeJayEight Thanks for the feedback I'll check with Kragen/Autozone/Pep Boys for the grade 8 or better bolts. Would you say by looking at the pic above that they are approximately 1" long?
Old Feb 11, 2006 | 02:04 PM
patdow1's Avatar
As an update to the original poster the brackets do not fit, at least mine didn't and my bar and brackets were from a 94 GSR.
Old Mar 8, 2006 | 06:52 AM
chanhlemonlime's Avatar
i believe you need gsr lower arms to make it work.
Old Mar 8, 2006 | 07:18 AM
Voyage34's Avatar
Default Re: GSR rear sway bar onto a 96-00 civic... will it fit? (chanhlemonlime)
gsr lower arms work on an EG but are too short for an EK
Old Mar 8, 2006 | 01:52 PM
nonsense's Avatar
Default Re: GSR rear sway bar onto a 96-00 civic... will it fit? (Voyage34)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Voyage34 &raquo;</TD></TR><TR><TD CLASS="quote">gsr lower arms work on an EG but are too short for an EK</TD></TR></TABLE>
not to mention EK lower arms already have teh hole needed for mounting the endlinks
EFRue57
Suspension & Brakes
Oct 16, 2009 06:20 AM
EFRue57
Oct 15, 2009 05:15 PM
MrIllegalX
Jan 20, 2004 05:52 AM
jimmhatch
Jan 8, 2004 09:22 AM
wdskuk
Sep 21, 2003 08:17 PM
