Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
94 Vigor Crank Angle sensor
Old Dec 26, 2005 | 06:51 AM
sohcvtec1995's Avatar
Default 94 Vigor Crank Angle sensor
Just a quick question.. Where is this sensor located? i have read that on the legend(v6) it is behind the timing belt... But i know that it is in the Dizzy on other makes and motors(I4). So where is the vigor (I5) on located?
Old Dec 26, 2005 | 08:23 AM
Kenso's Avatar
HT White Ops
Default Re: 94 Vigor Crank Angle sensor (sohcvtec1995)
Behind the cam sprocket.
Old Dec 26, 2005 | 04:29 PM
Default Re: 94 Vigor Crank Angle sensor (Kenso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kenso &raquo;</TD></TR><TR><TD CLASS="quote">Behind the cam sprocket.</TD></TR></TABLE>
isnt that the cam angle sensor? thats what i have read... Any one have a pic, or blueprint?
Old Dec 27, 2005 | 06:14 AM
Kenso's Avatar
HT White Ops
Both sensors use the cam sprocket. The cylinder position sensor is in front, the crank position sensor is behind the sprocket.
Old Dec 27, 2005 | 08:33 AM
Wow.. Thanks you very much.. Thats exactly what i needed..
Old Feb 10, 2006 | 08:45 AM
any tips on how to remove it simpiler? or maybe a step by step..
Old Feb 12, 2006 | 01:08 PM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
Default Re: (sohcvtec1995)
im sure all you have to do it remove the valve cover, and remove the upper plastic sheild and it should be visable.
Old Feb 13, 2006 | 12:09 PM
Sewer Rat's Avatar
You have to remove the cam pulley which means pulling the timing belt. The hardest part about that is pulling the harmonic balancer. You'll need to buy or build a tool to hold the balancer so you can break the bolt loose. It's torqued pretty tight (185 ft/lbs ?) so if you build a tool, make it with a long handle. Get a service manual of some sort, I have a Chilton's that sucks but it's better than nothing. At least it has pictures!
votex5
Jun 14, 2013 11:52 AM
MrDomino
Engine Management and Tuning
17
Apr 4, 2013 07:39 PM
Tonyng101
Acura TL, RL & ZDX
Jul 3, 2008 08:04 AM
jjmajed
Apr 12, 2007 01:13 PM
