EG hatch
if you look inbetween the top and bottom sections of the seats you will see two bolts unbolt those then lift the rear seat and bring it forward it will come right out then fold the top section down and you will know what to do from there
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wspcivic »</TD></TR><TR><TD CLASS="quote">theres those hooks that go under the floor do they just clip out? or do i have to push somthing to unhook them?</TD></TR></TABLE>
just roll the seat towards the front of the car and lift, the hooks go under the floor. hope that makes sense
There are clips on each side of the rear seat top. These are on the pins that go into the plastic on the outer bottom edge of the seat. Fold down the tops and look to the sides remove these clips, one on each side and remove seat tops. There is then a bolt on the back of the seat bottom that needs to be removed than just like previous post roll the back of the seat up and towards the front and the seat should just lift out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcVTECeg2 »</TD></TR><TR><TD CLASS="quote">maybe this could help
https://honda-tech.com/zerothread?id=512901</TD></TR></TABLE>
beat me 2 it...
beat me 2 it...
h45454
Mar 29, 2003 10:19 PM
sir2ef-8
Jan 27, 2002 06:27 AM
