Auto to Manaul Swap help please! need pics.
Sorry I know this have been posted in the FAQs, but that one dont have pics, So I was wondering if someone know any other links that has pics or atleast one that tells u how to take out the pedals... Thanks alot.
I belive this one will help you out, the guy who did it knows what he's doing.
https://honda-tech.com/zerothread?id=1337459
The hardest part about taking out the pedals is just getting the tools up there to them. If you get under there and look, you will see a couple 10mm bolts that hold the clutch pedal on. There is a pin that goes through the rod which enters the clutch resevoir that needs to be pulled out. With the brake pedal, just remove the solid pedal part by pulling out the lock pin, and then removing the pin holding the pedal on. Just pulling off the metal pedal will be so you dont' have to mess with the brake master cylinder. The hardest part on the brake pedal is actually putting the spring back into place. It took me like 10 minutes to do it.
I had my dash still in during the installation of the new pedals in my eg. It would be easier with it out, but it's still going to be difficult to get to. It wasn't as hard as I thought, since all of the how-to's actually say it is the most difficult part. I personally don't think that is the most difficult part.
EnSAn
Jul 16, 2006 04:33 AM
