Suspension & Brakes Theory, alignment, spring rates....
Skunk2 Camber Kit Question
Old Dec 25, 2005 | 02:51 PM
dohcVTECeg2's Avatar
Default Skunk2 Camber Kit Question
i just recently purchased a brand new pro series kit and i had a question.how much do the bolts (yellow arrows) have to be tightened down? are they supposed to be a bit loose or tightened down hard? this is my first time doing this work myself. i already have it all bolted on my car.
Old Dec 25, 2005 | 03:28 PM
00IntegrAllmotoR's Avatar
HT Black OPs
Default Re: Skunk2 Camber Kit Question (dohcVTECeg2)
i tightened down as much as i could, i could get the toque specs if you need it.
Old Dec 25, 2005 | 03:33 PM
PrinceAli132's Avatar
Default Re: Skunk2 Camber Kit Question (00IntegrAllmotoR)
If you talking about the nuts that go on those two bolts the torque specs for a dc are 47lbs.
Ali
Old Dec 26, 2005 | 12:03 AM
Default Re: Skunk2 Camber Kit Question (PrinceAli132)
it should be tightened once in the air. im going in for my alignment tomorrow, can they just do that when i take it in. im running the pro series skunk2 camber kit and omni coilovers
Old Dec 26, 2005 | 12:19 AM
Nope tighten it when the car is on the ground.
Ali
Old Dec 26, 2005 | 12:53 AM
how can i tighten it once its on the ground??? its hard to reach. im a noob at suspension
Old Dec 26, 2005 | 05:56 AM
Just to make sure, you are referring to the two bolts that are pointing upwards right. Or are you talking about the two bolts on the sides of the upper control control arm that are holding the two bolts.
I was refereing to the two bolts pointing upwards. Those two bolts go through the shock tower. So you have to pop your hood, and put the nut from on top of the shock tower, ant tighten from there. So once the car is on the ground then it shouldn't be hard at all.
Ali
Old Dec 26, 2005 | 07:53 AM
i am talking about the 2 bolts on the side of the upper control arm
Old Dec 26, 2005 | 08:48 AM
Sorry about that then, i have no idea. I think that they should be pretty tight but don't overdo it. But don't take my word for it, im not 100% sure. Sorry
Ali
AxKaose
Suspension & Brakes
Sep 28, 2009 08:46 AM
Charlie Moua
Suspension & Brakes
May 5, 2009 06:14 PM
iLOVEthatEMone
14
Jun 28, 2007 01:52 PM
euG3dc2r
May 1, 2007 06:14 PM
mdd
Suspension & Brakes
Jan 16, 2006 01:58 PM
