Test Pipe Gains
Old Mar 18, 2002 | 06:46 AM
Subtle's Avatar
Default Test Pipe Gains
I've seen a lot of talk about test pipes and the noise factor and such. I'm just curious about the performance gains on replacing the stock CC w/ a test pipe on a JRSC Si. Currently puts out 190 whp. Any rough estimates? Is it worth it?
Old Mar 18, 2002 | 07:05 AM
E. Honda's Avatar
Default Re: Test Pipe Gains (Subtle)
I've heard its worth it if you have a header with a large collector, 2.5 or so.
Old Mar 18, 2002 | 11:39 AM
image-evo1's Avatar
New User
i love my test pipe!!! I have a 2.5 inch straight pipe attached to the JDM DC header and i feel a gain in the high end of the rpm band! the noise level is a little louder but its not too bad. hoope that helps
Old Mar 18, 2002 | 12:19 PM
Subtle's Avatar
Default Re: Test Pipe Gains (image-evo1)
What kind of exhaust image? Greddy Evo I assume from name?
Old Mar 18, 2002 | 02:53 PM
Robster's Avatar
on most cars its about 2-3hp and 1-2 ft lbs of torque. Pumping as much air as you have going through there, it very well could be a major bottle neck trying to pump that many cfm's through there, with 190hp, I'd say you could probably gain 5-8hp and 3-5 ft lbs. Hell, they're cheap, do it. You can get custom ones made for roughly $50 (most shops) or if you have a hookup, it could be as cheap as how good of your hookup. Or you can go to http://www.testpipe.com and get one for rougly $30.
Old Mar 18, 2002 | 09:19 PM
image-evo1's Avatar
New User
i am actually running a tanabe exhaust. image-evo is just a crew of friends i kick it with... if you are looking for a pretty good test pipe i recommend the pipes from godspeed, they are pretty good. i got the test pipe for OBD-II cars so i can tune my car with that extra bung in the pipe. my car is OBD-I a, 95 coupe with B16a and type-r parts
[Modified by image-evo1, 6:21 AM 3/19/2002]
Old Mar 19, 2002 | 04:45 PM
JKim0901's Avatar
I dont like test pipes its because
1. It makes the ugly raspping sound.
2. It eats up the cotton stuff inside the muffler.
3. Getting caught with it in kali is a big *** fine.
but i still have one in my car imma take it out soon though. I think its good to have it around when you go to the track or something but other than that i dont like it and its not worth the 3 extra hp it gives.
Old Mar 19, 2002 | 04:56 PM
B_CRUZ!'s Avatar
if you have a dohc vtec motor or a wild *** cams in a LS i recommend a test pipe. when vtec kicks in, you are gonna need all the freeflow you can get.
Tong.Y
Jan 2, 2011 08:14 AM
rsxman
Aug 12, 2006 10:31 PM
3vilMonkey!
Honda S2000
21
Apr 12, 2006 08:57 AM
Steve04SVT
Nov 24, 2002 11:06 PM
RacerMike
12
May 23, 2002 09:13 AM
