Tire Pressure on 205/50/15
Old Dec 25, 2005 | 01:12 PM
RGoose18's Avatar
Default Tire Pressure on 205/50/15
What tire pressure are you guys running on 205/50/15 on both the front and rear? Thanks
Old Dec 25, 2005 | 01:26 PM
SpdFrk's Avatar
Default Re: Tire Pressure on 205/50/15 (RGoose18)
32psi
Old Dec 25, 2005 | 01:30 PM
KOALA YUMMIES's Avatar
Default Re: Tire Pressure on 205/50/15 (SpdFrk)
Right around 32psi. Track pressures around 40 psi hot or higher. Sometimes 1 or 2 psi lower in the rear.
Old Dec 25, 2005 | 02:20 PM
KayOs's Avatar
35 F
33 R
Pressure above on cold tires for daily driving.
Old Dec 25, 2005 | 06:30 PM
SoCal ITR's Avatar
Default Re: Tire Pressure on 205/50/15 (KayOs)
depends on the tire.
Old Dec 26, 2005 | 09:23 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KayOs &raquo;</TD></TR><TR><TD CLASS="quote">35 F
33 R
Pressure above on cold tires for daily driving.</TD></TR></TABLE>
Old Dec 26, 2005 | 10:47 AM
andyt's Avatar
36F
34R
Old Dec 26, 2005 | 11:14 AM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RGoose18 &raquo;</TD></TR><TR><TD CLASS="quote">What tire pressure are you guys running on 205/50/15 on both the front and rear? Thanks </TD></TR></TABLE>
30f/31r on Z214's
Not to open a can of worms, but what does YOUR doorjam say?
Old Dec 26, 2005 | 11:43 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Tire Pressure on 205/50/15 (Chris F)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F &raquo;</TD></TR><TR><TD CLASS="quote">30f/31r on Z214's</TD></TR></TABLE>
Those are track tires.
Hey goose, are you asking about track tires, or street tires?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F &raquo;</TD></TR><TR><TD CLASS="quote">Not to open a can of worms, but what does YOUR doorjam say?</TD></TR></TABLE>
It says "Honda Motor Co. Ltd."
Old Dec 26, 2005 | 01:46 PM
Default Re: Tire Pressure on 205/50/15 (KOALA YUMMIES)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KOALA YUMMIES &raquo;</TD></TR><TR><TD CLASS="quote">Right around 32psi. Track pressures around 40 psi hot or higher. Sometimes 1 or 2 psi lower in the rear. </TD></TR></TABLE>
This is for street tires, for both my Bridgestone Potenza S0-3s, and Falken Azenis RT-615. The hot temperature is just after cool down from a 20 min session for the Azenis.
Old Dec 26, 2005 | 02:46 PM
1GreyTeg's Avatar
Default Re: Tire Pressure on 205/50/15 (SoCal ITR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoCal ITR &raquo;</TD></TR><TR><TD CLASS="quote">depends on the tire.</TD></TR></TABLE>
Old Dec 26, 2005 | 02:53 PM
Arsenal's Avatar
Default Re: Tire Pressure on 205/50/15 (1GreyTeg)
How about a Falken Ziex 512, anyone else running them?
Old Dec 26, 2005 | 04:25 PM
RGoose18's Avatar
Default Re: Tire Pressure on 205/50/15 (nsxtasy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">
Street tires, just some toyo proxes all season, what's your opinion on this nsxtacy, theres a ton of numbers being thrown around and I figure it has to be different than stock pressure of 35/33
Old Dec 26, 2005 | 04:47 PM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RGoose18 &raquo;</TD></TR><TR><TD CLASS="quote">Street tires, just some toyo proxes all season, what's your opinion on this nsxtacy, theres a ton of numbers being thrown around and I figure it has to be different than stock pressure of 35/33</TD></TR></TABLE>
Why do you figure it has to be different? That's the stock pressure recommended for both the ITR and the GS-R. Using those pressures, I've had even tire wear across the width of the tread, for my summer tires as well as my winter tires, and the handling has seemed pleasantly neutral. If they were not the optimal pressures, you would expect to see more wear in the center than the edges (overinflation) or the reverse (underinflation), or handling quirks, but I haven't.
I use 1-3 pounds less in my track tires, but that's a separate story.
All pressures measured cold (tires at ambient temperature, not in the sun, after the car has been sitting a while).
Old Dec 26, 2005 | 05:08 PM
Arsenal's Avatar
I think that the original poster would think it would be different due to a different tire size; along with myself?
Old Dec 26, 2005 | 05:29 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Tire Pressure on 205/50/15 (Arsenal)
Not necessarily. Especially when the tire size in question is so close in size to the stock size.
Old Dec 26, 2005 | 05:51 PM
totsie7944's Avatar
I keep mine around 40psi.... Other wise I feel like the tires roll around corners a bit. Michelin Exaltos. really good tires.
RGoose18
Sep 1, 2007 07:56 AM
pnoi_01dc2r
May 28, 2007 07:24 AM
jonzel
Dec 7, 2006 10:20 AM
RatRedV8Datsun
Apr 16, 2003 05:26 PM
Renegade
Apr 4, 2002 01:05 PM
