welding question
Old Dec 25, 2005 | 11:04 AM
tallyturbo's Avatar
Default welding question
im new to welding and i have a chichago electric wire feed welder. i am using it on a generator in my back yard, is that a bad thing? also i can feed the wire through the gun but i cannot get it to produce an arc. do you think that im not getting enough power or something. i have been reading all day and i cant come to any conclusions. any help will be appriciated. thanks
Old Dec 25, 2005 | 11:39 AM
BigStun's Avatar
Default Re: welding question (tallyturbo)
please tell me you have your work grounded?
Old Dec 25, 2005 | 11:43 AM
tallyturbo's Avatar
Default Re: welding question (BigStun)
yep it is definatly grounded
Old Dec 25, 2005 | 11:16 PM
90DALS's Avatar
make sure the welding area is prepped, as in, your not welding ontop of paint etc.
Old Dec 26, 2005 | 06:58 AM
tallyturbo's Avatar
Default Re: (90DALS)
ya it is raw metal and i hit it with a wire brush pretty good. my dad said i wasnt getting a good ground but i dont see how i would get any better. the ground clip is on there the best it can be.
Old Dec 26, 2005 | 07:14 AM
tonydatyga's Avatar
Default Re: (tallyturbo)
the ground is through the paint on the bare metal?
Old Dec 26, 2005 | 07:41 AM
tallyturbo's Avatar
Default Re: (tonydatyga)
ya there isnt any paint on the metal so that shouldnt be the problem. ill mess around with it a little bit today and tell yaul what happens
Old Dec 26, 2005 | 08:23 AM
cua0's Avatar
check your contact tip, make sure that it's fairly tight around the wire, make sure that you don't have any broken cables or wires inside the machine or the whip.
other than that i don't know what to tell you.
Old Dec 26, 2005 | 09:05 AM
dfoxengr's Avatar
Default Re: (cua0)
you need to open up the welder to see if the power cable is connected to your gun lead.
Old Dec 26, 2005 | 09:18 AM
tallyturbo's Avatar
Default Re: (dfoxengr)
will do
Old Dec 26, 2005 | 02:21 PM
tallyturbo's Avatar
my dad fixed it. something about the power lead or something. thanks for all the help. ill try to post some pics of some pipe i welded together. they came out pretty good imo.
Old Dec 26, 2005 | 02:27 PM
dfoxengr's Avatar
like i said, wahoo
DA-9mordef
Apr 24, 2024 07:52 PM
B_Swapped93
Apr 30, 2013 03:15 PM
91ed9
Welding / Fabrication
20
Dec 15, 2007 11:59 AM
Rob_Dog
Nov 11, 2004 02:55 AM
ckkl
Mar 10, 2003 07:47 AM
