Windshield washer sprayers don't go on CF hood, where do i put them?
I have no place to put the sprayers, and they are definetly not going on my hood. What do i do? I know i don't need them, but they are nice to have.
where would i go to find the wiper mounted kind? i have heard of them but never seen them. do i have to get new wipers too or no, because i just bought new wipers two weeks ago. oh well they were cheap.
You can probably use a kit like this:
http://www.rustrepair.com/STEP...T.ARM
or this:
http://www.prdonline.com/catal...d=287
Personally though, I would just drill the necessary holes in the hood to install the stock nozzles.
or this:
well i dont know if it works or not but i know the intergras had their washer nozzles mounted on the cowl panel where the wipers hook up. If they are attached the same, it should work. Ill have to do that on mine this weekend now and see if it works. Ill let you know
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicliveit »</TD></TR><TR><TD CLASS="quote">well i dont know if it works or not but i know the intergras had their washer nozzles mounted on the cowl panel where the wipers hook up. If they are attached the same, it should work. Ill have to do that on mine this weekend now and see if it works. Ill let you know</TD></TR></TABLE>
get the integra cowl, it fits perfect, but you need to raise the rear of the hood a little to clear the nozzles
i would not drill your own holes i can see that turning into disaster... I would just configure something to hold the tubes on the wiper or just drive without them... personally i use mine 3 or 4 times a year i bet you wouldnt miss them
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slow_CvC99 »</TD></TR><TR><TD CLASS="quote"> personally i use mine 3 or 4 times a year i bet you wouldnt miss them</TD></TR></TABLE>
What's the weather like in WI? ever drive north? If you ever plan on driving where snow is, install them. I personally use mine at every red light, and a few times inbetween....lol
Cheers and enjoy the season.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by old man neri »</TD></TR><TR><TD CLASS="quote">
Cheers and enjoy the season.</TD></TR></TABLE>
I live in IL the salt capital
it doesnt bother me i just wipe it off at gas stations or i take me lazy *** outside with a bottle of windex and paper towel
Cheers and enjoy the season.</TD></TR></TABLE>Honestly that's just habit. Even in Canadian winters I didn't need them.
my cf hood came with washer holes to put the washers in them...but then the washers didn't fit. So all I did was sanded the edges with a file...fits perfect now. But if you have to drill washer holes...hope it turns out good for you.
Do what they have on the DA Integras. The are mounted right under the bottom side of the hood, closest to the windshield. I'm sure you can think of someway to fashion them there.
you might try to see if the wiper blade off of a newer cavalier (01-present) will work they have the squirters on the blades
